[Mapserver-users] FW: WMS Client for ArcView 3.X
kenboss kenboss at dilbert.dnr.state.mn.us
Thu Oct 9 15:11:56 EDT 2003
ArcView 3.x is pretty much braindead when it comes to transparency in
truecolor/24-bit/3-band images.  You can set a transparent color on a
single-band colormapped image, but there is no such functionality corresponding
to multi-band images, unless you want to shell out extra cash for ESRI's Image
Analyst extension.
Ken Boss
MN DNR Forestry Resource Assessment
> -----Original Message-----
> From: Julia Harrell [mailto:julia.harrell at ncmail.net]
> Sent: Thursday, October 09, 2003 2:24 PM
> To: julia.harrell at ncmail.net
> Subject: RE: WMS Client for ArcView 3.X
> This is a nice extension and has a lot of
> potential whenever the GetFeatureInfo becomes
> a reality. Thanks for Refractions for building it!
> I was experimenting with breaking our many-layered WMS
> map services into a number of separate OGC files, and
> discovered that even though my WMS Mapservice outputs both
> transparent pngs and gifs, that the images the av wms connector
> brings into Arcview are not transparent. Unless there are some
> other Av extensions that I haven't heard of, Arcview 3x
> doesn't understand pngs and gifs, so these must be
> Jpgs or something else that does not support transparency??
> Does anyone have any workarounds or suggestions for fooling
> the colormaps into thinking that 255,255,255 is the
> 'transparent' color, so I can look at more than one layer
> At a time ?
> I checked Shane's "magic log file" and saw the connector
> is asking for gif images. I guess that dll the
> Connector installs is converting these gifs on the fly
> to something Arcview 3x supports. Where is this connector
> stashing its' images? I'm seeing a lot of ximg.bip & ximg.hdr
> files in my Documents and Settings\xxx\Local Settings\Temp
> directory that have the right timestamps - is this them?
> I tried opening them in Irfanview and PSP, but neither
> could read them, and I tried loading them into Arcview,
> but get nothing viewable....
> Example County & City Boundaries request:
> http://204.211.135.111/servlet/com.esri.wms.Esrimap?SERVICENAME=cgia_defwms&
> Format=image/gif&Version=1.1.0&Layers=CountyBoundary,CityLimit2001&Styles=&R
> equest=getmap&Srs=EPSG:4326&bbox=%2D78%2E694869401434005,35%2E68303912973367
> 9,%2D78%2E438688814369328,35%2E903327035616023&width=935&height=803&Exceptio
> ns=application/vnd.ogc.se_xml&
> Example Roads request
> Format=image/gif&Version=1.1.0&Layers=LocalRoads,NCSecRoutes,PrimRoutes,Inte
> rstates,BlueRidgeParkway&Styles=&Request=getmap&Srs=EPSG:4326&bbox=%2D78%2E6
> 94869401434005,35%2E683039129733679,%2D78%2E438688814369328,35%2E90332703561
> 6023&width=935&height=803&Exceptions=application/vnd.ogc.se_xml&
> Thanks much for any suggestions,
> Julia Harrell
> NC CGIA
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
