[Mapserver-users] Mapserver 4 Makefile for VC + compile problems
Stephen Clark stephen.clark at focus.ca
Fri Oct 10 13:52:07 EDT 2003
Brent and others,
Thanks for the effort with my compilation problems.
We should post an update to the WIKI and the DOCS for MS 4.0 and the
supporting libraries that have changes since:
http://mapserver.gis.umn.edu/doc40/win32_compile-howto.html
was originally written.
thanks,
Stephen
----- Original Message -----
To: "Stephen Clark" <stephen.clark at focus.ca>;
<mapserver-users at lists.gis.umn.edu>
Sent: Thursday, October 09, 2003 3:43 PM
Subject: Re: [Mapserver-users] Mapserver 4 Makefile for VC + compile
problems
> Stephen (and others who would like to compile with VC++),
>   I attached instructions for building Mapserver and the dependencies with
> VC++.  It's not THE way, just MY way.  (Now that there is an excellent
> nmake.opt file with Mapserver,  I'll have to update my doc to use it...)
> Hope it helps...
> Brent
> From: "Stephen Clark" <stephen.clark at focus.ca>
> To: "Swaminathan, Gayathri" <gayathri at ou.edu>;
> Sent: Thursday, October 09, 2003 3:19 PM
> problems
> > Hello,
> > I have commented out all the optional libraries and am just left with
the
> > basic mapserver.
> > I have included the "makefile.vc"  "nmake.opt" and the latest compile
> error
> > listing.
> > It appears that the regex library is looking for an external library
> > "_printchar"
> > I compiled using the following steps:
> > 1. Compiled png library Version 1.2.5
> > 2. Compiled zlib library Version 1.1.4
> > 3. Compiled GD version 2.0.15
> > I removed the reference to the JPEG library because I was getting an
> > error...
> > 4. Compiled mapserver 4.0 (stable version as indicated below)
> > 5. Got the errors I am posting.
> > thanks
> > Stephen
> > From: "Swaminathan, Gayathri" <gayathri at ou.edu>
> > To: "'Stephen Clark'" <stephen.clark at focus.ca>;
> > Sent: Thursday, October 09, 2003 11:43 AM
> > Subject: RE: [Mapserver-users] Mapserver 4 Makefile for VC + compile
> > problems
> > > Hello:
> > > You will certainly need to compile the required libraries before you
> > proceed
> > > compiling mapserver.
> > > Please find in the attachment my gd makefile, that should work for
> command
> > > line compilation of GD. You will need to download the version 2+ from,
> > > http://www.boutell.com/gd
> > > Now here is a simple solution to compiling mapserver 4,
> > > 1) Download required libraries that is (Please find links for all
these
> at
> > > http://mapserver.gis.umn.edu/doc40/win32_compile-howto.html),
> > >    a)GD Library
> > >    b)PNG library
> > >    c)Zlib
> > >    d)Regex
> > > GD in turn needs,
> > >    a) Zlib and,
> > >    b) Freetype
> > > (You should be able to comment out JPEG stuff in the included makefile
> for
> > > GD and compile the same).
> > > Alternatively you can compile GD easily using the MSVC++ workspace
> too...
> > > As mentioned in the
> > > http://mapserver.gis.umn.edu/doc40/win32_compile-howto.html the
> following
> > > are optional,
> > > 1) Proj.4- easy compile-clean makefile
> > > 2) GDAL - easy compile-clean makefile
> > > 3) LIBTIFF-  easy compile-clean makefile
> > > 4) LIBJPEG- kind of messy
> > > 5) ArcSDE - I have not tried this option
> > > 6) EPPL7 - included with mapserver src., you will have turn on a
switch
> > for
> > > this to get included.
> > > Follow the instructions in mapserver docs, for compile for
> > > commenting/uncomenting (including, excluding) options.....
> > > Compile these libraries in your project directory first...
> > > Download mapserver source., from here,
> > > http://cvs.gis.umn.edu/dist/mapserver-4.0.tar.gz ( this one should not
> > cause
> > > any troubles..)
> > > You probably do not want the CVS one which is a developer version.,
> > certain
> > > things may be unstable there)...
> > > Mapserver make is a breeze too. Just turn on  the required libraries
in
> > the
> > > nmake.opt and follow instructions in makefile.vc.
> > > It should all work right...
> > > Bon Appetite!
> > > Gayathri
> > > PS: Please do let me know if you would like for me to help in this
> > process.,
> > > that is FTP to a site you would mention, my compiled libraries,
> makefiles
> > > etc...If yes,let me know of the FTP location, username, passwd...
> > > -----Original Message-----
> > > From: Stephen Clark [mailto:stephen.clark at focus.ca]
> > > Sent: Thursday, October 09, 2003 1:28 PM
> > > To: Swaminathan, Gayathri; mapserver-users at lists.gis.umn.edu
> > > problems
> > > Hi
> > > Item #1:
> > > Does anyone have a makefile.vc for the GD-2.x version that will
compile
> > with
> > > Visual C 6? So far I have got to the point where the mapserver compile
> > stops
> > > at this library.
> > > Item #2:
> > > http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapServerCompilation
> > > and http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MicrosoftWindows
> > > on the wiki site does not really explain compiling very well for
> mapserver
> > > using Visual C++ Ver 6.
> > > (Specifically the use of the nmake site)
> > > I was wondering if someone could post their instructions.
> > > I believe that I may be trying to compile mapserver before the other
> > > supportin libraries are compiled. If it is correct to assume that the
> > > supportuing libraries are to be compiled before mapserver, would
someone
> > > shed some light on their "best" solution?
> > > thanks,
> > > Stephen
> > > Sent: Thursday, October 09, 2003 6:21 AM
> > > > Stephen,
> > > > The gdal error is coming because....you have forgot/dint comment the
> > > > following line in Makefile.vc
> > > > "copy $(GDAL_DIR)\gdal.pdb ."
> > > > Comment the same by including a "#" in the beginning of the line.
> > > > On examining your nmake.opt, I see "c:\project" to be your working
> > > > directory...Is this correct? Are all the required libraries in here?
> > > > Have they been compiled before you proceeded to compile mapserver
4.0?
> > > > Cheers,
> > > > Gayathri
> > > > Sent: Wednesday, October 08, 2003 1:32 PM
> > > > To: mapserver-users at lists.gis.umn.edu
> > > > I have included my makefile.vc and nmake.opt files as well as the
> > > > compile errors foer your consideration.
> > > > thanks,
> > > > Stephen
> > > > To: "Swaminathan, Gayathri" <gayathri at ou.edu>; "'Yewondwossen
Assefa'"
> > > > <assefa at dmsolutions.ca>
> > > > Cc: <mapserver-users at lists.gis.umn.edu>
> > > > Sent: Wednesday, October 08, 2003 10:23 AM
> > > > > Could someone post their makefile.vc and nmake.opt files.
> > > > > I would like a version that has the minimum set of options set
> > > > > whichI can then modify.
> > > > > thanks
> > > > > Stephen
> > > > > To: "'Yewondwossen Assefa'" <assefa at dmsolutions.ca>
> > > > > Sent: Friday, September 19, 2003 8:03 AM
> > > > > > Missed that when looking, but after careful examination saw this
> > > > > > file.,
> > > > > > Thanks all as always for your patience and time on this.
> > > > > > Gayathri
> > > > > > From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> > > > > > Sent: Thursday, September 18, 2003 9:26 PM
> > > > > > Cc: mapserver-users at lists.gis.umn.edu
> > > > > > Hi There,
> > > > > >   There are now 2 files involved in the process, makefile.vc and
> > > > > > nmake.opt  where all the options are included. This separation
> > > > > > makes things clearer and the option file can be used by sub
> > > > > > projects like php/mapscript. All settings for necessary
libraries
> > > > > > + optional libraries are inside the nmake.opt.
> > > > > > Later,
> > > > > > Swaminathan, Gayathri wrote:
> > > > > > > Hi all:
> > > > > > > After being content with mapserver-3.6.5 for a long time now,
I
> > > > > > > was getting ready to compile mapserver 4.0 and test it.
> > > > > > > There are several changes that I notice between
mapserver-3.6.5
> > > > > > > and mapserver-4.0. The makefile.vc in the package shrinked. I
> > > > > > > assumed this is not the One that I should be using and
proceeded
> > > > > > > with alterations to my old makefile.vc that came from
> > > > > > > mapserver-3.6.5
> > > > > > > I was finally sucessful in building a mapserver with the
> > > > > > > following enabled.
> > > > > > > MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> > > > > > > SUPPORTS=PROJ INPUT=EPP L7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> > > > > > > INPUT=SHAPEFILE
> > > > > > > I need WMS server and WMS Client with this. I see that libcurl
> > > > > > > is being used somehow and keep getting errors on the same.
> > > > > > > Please, indicate to me the right corrections to makefile.vc
(or)
> > > > > > > tell me where am I going wrong in this process.
> > > > > > > Thanks so much for your time on this.
> > > > > > > Gayathri _______________________________________________
> > > > > > > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > > > > > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > > > > > Assefa Yewondwossen
> > > > > > Software Analyst
> > > > > > Email: assefa at dmsolutions.ca
> > > > > > http://www.dmsolutions.ca/
> > > > > > Phone: (613) 565-5056 (ext 14)
> > > > > > Fax:   (613) 565-0925
