[Mapserver-users] Mapserver 4 Makefile for VC + compile problems
Brent Fraser bfraser at geoanalytic.com
Thu Oct 9 18:43:37 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0054_01C38E84.7C6BE960
Content-Type: text/plain;
	charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
Stephen (and others who would like to compile with VC++),
  I attached instructions for building Mapserver and the dependencies with
VC++.  It's not THE way, just MY way.  (Now that there is an excellent
nmake.opt file with Mapserver,  I'll have to update my doc to use it...)
Hope it helps...
Brent
----- Original Message -----
To: "Swaminathan, Gayathri" <gayathri at ou.edu>;
<mapserver-users at lists.gis.umn.edu>
Sent: Thursday, October 09, 2003 3:19 PM
Subject: Re: [Mapserver-users] Mapserver 4 Makefile for VC + compile
problems
> Hello,
> I have commented out all the optional libraries and am just left with the
> basic mapserver.
> I have included the "makefile.vc"  "nmake.opt" and the latest compile
error
> listing.
> It appears that the regex library is looking for an external library
> "_printchar"
> I compiled using the following steps:
> 1. Compiled png library Version 1.2.5
> 2. Compiled zlib library Version 1.1.4
> 3. Compiled GD version 2.0.15
> I removed the reference to the JPEG library because I was getting an
> error...
> 4. Compiled mapserver 4.0 (stable version as indicated below)
> 5. Got the errors I am posting.
> thanks
> Stephen
> From: "Swaminathan, Gayathri" <gayathri at ou.edu>
> To: "'Stephen Clark'" <stephen.clark at focus.ca>;
> Sent: Thursday, October 09, 2003 11:43 AM
> Subject: RE: [Mapserver-users] Mapserver 4 Makefile for VC + compile
> problems
> > Hello:
> > You will certainly need to compile the required libraries before you
> proceed
> > compiling mapserver.
> > Please find in the attachment my gd makefile, that should work for
command
> > line compilation of GD. You will need to download the version 2+ from,
> > http://www.boutell.com/gd
> > Now here is a simple solution to compiling mapserver 4,
> > 1) Download required libraries that is (Please find links for all these
at
> > http://mapserver.gis.umn.edu/doc40/win32_compile-howto.html),
> >    a)GD Library
> >    b)PNG library
> >    c)Zlib
> >    d)Regex
> > GD in turn needs,
> >    a) Zlib and,
> >    b) Freetype
> > (You should be able to comment out JPEG stuff in the included makefile
for
> > GD and compile the same).
> > Alternatively you can compile GD easily using the MSVC++ workspace
too...
> > As mentioned in the
> > http://mapserver.gis.umn.edu/doc40/win32_compile-howto.html the
following
> > are optional,
> > 1) Proj.4- easy compile-clean makefile
> > 2) GDAL - easy compile-clean makefile
> > 3) LIBTIFF-  easy compile-clean makefile
> > 4) LIBJPEG- kind of messy
> > 5) ArcSDE - I have not tried this option
> > 6) EPPL7 - included with mapserver src., you will have turn on a switch
> for
> > this to get included.
> > Follow the instructions in mapserver docs, for compile for
> > commenting/uncomenting (including, excluding) options.....
> > Compile these libraries in your project directory first...
> > Download mapserver source., from here,
> > http://cvs.gis.umn.edu/dist/mapserver-4.0.tar.gz ( this one should not
> cause
> > any troubles..)
> > You probably do not want the CVS one which is a developer version.,
> certain
> > things may be unstable there)...
> > Mapserver make is a breeze too. Just turn on  the required libraries in
> the
> > nmake.opt and follow instructions in makefile.vc.
> > It should all work right...
> > Bon Appetite!
> > Gayathri
> > PS: Please do let me know if you would like for me to help in this
> process.,
> > that is FTP to a site you would mention, my compiled libraries,
makefiles
> > etc...If yes,let me know of the FTP location, username, passwd...
> > -----Original Message-----
> > From: Stephen Clark [mailto:stephen.clark at focus.ca]
> > Sent: Thursday, October 09, 2003 1:28 PM
> > To: Swaminathan, Gayathri; mapserver-users at lists.gis.umn.edu
> > problems
> > Hi
> > Item #1:
> > Does anyone have a makefile.vc for the GD-2.x version that will compile
> with
> > Visual C 6? So far I have got to the point where the mapserver compile
> stops
> > at this library.
> > Item #2:
> > http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapServerCompilation
> > and http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MicrosoftWindows
> > on the wiki site does not really explain compiling very well for
mapserver
> > using Visual C++ Ver 6.
> > (Specifically the use of the nmake site)
> > I was wondering if someone could post their instructions.
> > I believe that I may be trying to compile mapserver before the other
> > supportin libraries are compiled. If it is correct to assume that the
> > supportuing libraries are to be compiled before mapserver, would someone
> > shed some light on their "best" solution?
> > thanks,
> > Stephen
> > Sent: Thursday, October 09, 2003 6:21 AM
> > > Stephen,
> > > The gdal error is coming because....you have forgot/dint comment the
> > > following line in Makefile.vc
> > > "copy $(GDAL_DIR)\gdal.pdb ."
> > > Comment the same by including a "#" in the beginning of the line.
> > > On examining your nmake.opt, I see "c:\project" to be your working
> > > directory...Is this correct? Are all the required libraries in here?
> > > Have they been compiled before you proceeded to compile mapserver 4.0?
> > > Cheers,
> > > Gayathri
> > > Sent: Wednesday, October 08, 2003 1:32 PM
> > > To: mapserver-users at lists.gis.umn.edu
> > > I have included my makefile.vc and nmake.opt files as well as the
> > > compile errors foer your consideration.
> > > thanks,
> > > Stephen
> > > From: "Stephen Clark" <stephen.clark at focus.ca>
> > > To: "Swaminathan, Gayathri" <gayathri at ou.edu>; "'Yewondwossen Assefa'"
> > > <assefa at dmsolutions.ca>
> > > Cc: <mapserver-users at lists.gis.umn.edu>
> > > Sent: Wednesday, October 08, 2003 10:23 AM
> > > > Could someone post their makefile.vc and nmake.opt files.
> > > > I would like a version that has the minimum set of options set
> > > > whichI can then modify.
> > > > thanks
> > > > Stephen
> > > > To: "'Yewondwossen Assefa'" <assefa at dmsolutions.ca>
> > > > Sent: Friday, September 19, 2003 8:03 AM
> > > > > Missed that when looking, but after careful examination saw this
> > > > > file.,
> > > > > Thanks all as always for your patience and time on this.
> > > > > Gayathri
> > > > > From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> > > > > Sent: Thursday, September 18, 2003 9:26 PM
> > > > > Cc: mapserver-users at lists.gis.umn.edu
> > > > > Hi There,
> > > > >   There are now 2 files involved in the process, makefile.vc and
> > > > > nmake.opt  where all the options are included. This separation
> > > > > makes things clearer and the option file can be used by sub
> > > > > projects like php/mapscript. All settings for necessary libraries
> > > > > + optional libraries are inside the nmake.opt.
> > > > > Later,
> > > > > Swaminathan, Gayathri wrote:
> > > > > > Hi all:
> > > > > > After being content with mapserver-3.6.5 for a long time now, I
> > > > > > was getting ready to compile mapserver 4.0 and test it.
> > > > > > There are several changes that I notice between mapserver-3.6.5
> > > > > > and mapserver-4.0. The makefile.vc in the package shrinked. I
> > > > > > assumed this is not the One that I should be using and proceeded
> > > > > > with alterations to my old makefile.vc that came from
> > > > > > mapserver-3.6.5
> > > > > > I was finally sucessful in building a mapserver with the
> > > > > > following enabled.
> > > > > > MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> > > > > > SUPPORTS=PROJ INPUT=EPP L7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> > > > > > INPUT=SHAPEFILE
> > > > > > I need WMS server and WMS Client with this. I see that libcurl
> > > > > > is being used somehow and keep getting errors on the same.
> > > > > > Please, indicate to me the right corrections to makefile.vc (or)
> > > > > > tell me where am I going wrong in this process.
> > > > > > Thanks so much for your time on this.
> > > > > > Gayathri _______________________________________________
> > > > > > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > > > > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > > > > Assefa Yewondwossen
> > > > > Software Analyst
> > > > > Email: assefa at dmsolutions.ca
> > > > > http://www.dmsolutions.ca/
> > > > > Phone: (613) 565-5056 (ext 14)
> > > > > Fax:   (613) 565-0925
Content-Type: application/x-zip-compressed;
	name="default.zip"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
	filename="default.zip"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------=_NextPart_000_0054_01C38E84.7C6BE960--
