[Mapserver-users] EXTENT of map object
Eduardo Patto Kanegae eduardo at consultoria.eti.br
Fri Oct 10 07:26:41 EDT 2003
u have to have some data to get extent of a map.
u could create a point shapefile and create 2 points( 1 at lower-left and other at upper-right)
http://www.consultoria.eti.br - BRASIL
***Fim da Mensagem / End of Message ***
On Fri, 10 Oct 2003 15:27:53 +0000, Mukta Telang <mukta at darya.nio.org> escreveu:
> De: Mukta Telang <mukta at darya.nio.org>
> Data: Fri, 10 Oct 2003 15:27:53 +0000
> Para: mapserver-users <mapserver-users at lists.gis.umn.edu>
> Assunto: [Mapserver-users] EXTENT of map object
> Hi,
> The mapfile reference describes EXTENT as the spatial extent of the map
> to be created. I dont have data in shapefile or any other format. All I
> want to do is display an image in tiff/jpeg format which the user should
> be able to zoom by clicking on some points. How do I find EXTENT of map
> in this case?
> Thanks in advance,
> Mukta
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
