[Mapserver-users] ECW Example
bartvde at xs4all.nl bartvde at xs4all.nl
Mon Oct 13 07:46:22 EDT 2003
Hi Omry,
can you always cc the mailing list please?
You can use gdalinfo.exe for this.
See:
http://gdal.maptools.org/gdal_utilities.html
Best regards,
Bart
> Hi Bart,
> How do I find the correct extent for my sample ECW file?
> -----Original Message-----
> From: Bart van den Eijnden [mailto:bartvde at xs4all.nl]
> Sent: à 12 àå÷èåáø 2003 18:06
> To: Omry Yadan; mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] ECW Example
> Hi,
> attached an example map file which uses ECW files.
> I think ECW is generally a good format to use, but also depending on your
> color depth (ECW is always 24-bit). I did not find any big performance
> improvement using tiles for my specific situation in which the largest ECW
> file was 5 Gb.
> Best regards,
> Bart
> # Start of map file
> NAME GEOSTREETS
> STATUS ON
> SIZE 600 600
> #EXTENT 388107.634400379 5203120.88405952 500896.339019834
> 5310243.30613897
> EXTENT 150000 300000 260000 630000
> UNITS METERS
> IMAGECOLOR 255 255 255
> # Start of web interface definition (including WMS enabling metadata)
> WEB
>   HEADER demo_header.html
>   TEMPLATE demo.html
>   FOOTER demo_footer.html
>   MINSCALE 50
>   MAXSCALE 155000000000
>   IMAGEPATH "set in demo_init.html"
>   IMAGEURL "set in demo_init.html"
>   METADATA
>     WMS_TITLE "UMN MapServer Geostreets"
>     WMS_ABSTRACT "UMN MapServer Geostreets"
>     WMS_ACCESSCONSTRAINTS none
>     WMS_ONLINERESOURCE "http://localhost:8081/bart/demo_init.html"
>     WMS_SRS "EPSG:28992"
>   END
> END
> # Start of layer definitions
> LAYER
>       NAME "layer_1"
>       TILEINDEX "E:\bart\ecw\geostreets.shp"
>       TILEITEM "location"
>       #DATA "E:\klicnet\data\webstreets\Gstreets_2003\ecw\level1.ecw"
>       TYPE RASTER
>       MINSCALE 0
>       MAXSCALE 12000
>       STATUS ON
>       DUMP TRUE
>   METADATA
>     WMS_TITLE "Geostreets Level 1"
>     WMS_ABSTRACT "Geostreets Level 1"
>   END
> END
> LAYER
>       NAME "layer_2"
>       DATA "E:\klicnet\data\webstreets\Gstreets_2003\ecw\level2.ecw"
>       TYPE RASTER
>       MINSCALE 12000
>       MAXSCALE 25000
>       STATUS ON
>       DUMP TRUE
>   METADATA
>     WMS_TITLE "Geostreets Level 2"
>     WMS_ABSTRACT "Geostreets Level 2"
>   END
> END
> LAYER
>       NAME "layer_3"
>       DATA "E:\klicnet\data\webstreets\Gstreets_2003\ecw\level3.ecw"
>       TYPE RASTER
>       MINSCALE 35000
>       MAXSCALE 100000
>       STATUS ON
>       DUMP TRUE
>   METADATA
>     WMS_TITLE "Geostreets Level 3"
>     WMS_ABSTRACT "Geostreets Level 3"
>   END
> END
> LAYER
>       NAME "layer_4"
>       DATA "E:\klicnet\data\webstreets\Gstreets_2003\ecw\level4.ecw"
>       TYPE RASTER
>       MINSCALE 100000
>       MAXSCALE 250000
>       STATUS ON
>       DUMP TRUE
>   METADATA
>     WMS_TITLE "Geostreets Level 4"
>     WMS_ABSTRACT "Geostreets Level 4"
>   END
> END
> LAYER
>       NAME "layer_5"
>       DATA "E:\klicnet\data\webstreets\Gstreets_2003\ecw\level5.ecw"
>       T
> YPE RASTER
>       MINSCALE 250000
>       MAXSCALE 1000000
>       STATUS ON
>       DUMP TRUE
>   METADATA
>     WMS_TITLE "Geostreets Level 5"
>     WMS_ABSTRACT "Geostreets Level 5"
>   END
> END
> LAYER
>       NAME "layer_6"
>       DATA "E:\klicnet\data\webstreets\Gstreets_2003\ecw\level6.ecw"
>       TYPE RASTER
>       MINSCALE 1000000
>       MAXSCALE 15000000
>       STATUS ON
>       DUMP TRUE
>   METADATA
>     WMS_TITLE "Geostreets Level 6"
>     WMS_ABSTRACT "Geostreets Level 6"
>   END
> END
> END # Map File
> On Sun, 12 Oct 2003 17:38:35 +0200, Omry Yadan <omry at telmap.com> wrote:
>> 1.	Can someone send me an example for a map file for ECW?
>> 2.	What would you recommend as a format for large raster map With
>> tiles?
