[Mapserver-users] Raster files problem
    Jan Hartmann
    jhart at frw.uva.nl
    Mon Oct 13 05:24:01 PDT 2003
Omry,
You have to set STATUS DEFAULT to get a visible map. With STATUS ON, you
have to specify the layer explicitly in the URL
(.../mapserv?map=...&layer=...)
MapServer ignores non-existing raster files when it is compiled with the
--enable-ignore-missing-data flag (the default). I always compile with
--disable-ignore-missing-date for development, and only ignore missing
data for production.
Not seeing anything without an error is generally caused by:
- wrong extent
- status on instead of default
- incorrect raster file name
HTH
Jan
Omry Yadan wrote:
> I am trying to show an ECW raster file, and I am unable to get anything.
> I do not get an error, but the image I get is empty.
> A weird thing is, that even when I deliberately fuck up the file name, I
> don't get an error.
> It seems like the data is totally ignored...
> And idea?
> This is my map file:
> MAP
> 	NAME Sample
> 	STATUS ON
> 	SIZE 600 600
> 	EXTENT 660000 7680000 810000 7790000
> 	PROJECTION
> 	 "init=epsg:28354"
> 	END
> 	LAYER
> 		NAME "layer_1"
> 		DATA "c:\projects\ecw\sf5504.ecw"
> 		TYPE RASTER
> 		MINSCALE 1
> 		MAXSCALE 25000
> 		STATUS ON
> 	END
> END # Map File
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
