[Mapserver-users] Raster files problem
Omry Yadan
omry at telmap.com
Mon Oct 13 09:24:25 EDT 2003
Great!
After changing to this, it worked.
Thanks!
I had to remove the MINSCALE and MAXSCALE.
How to interpret the values in those parameters?
MAP
NAME Sample
SIZE 600 600
EXTENT 660000 7680000 810000 7790000
PROJECTION
"init=epsg:28354"
END
LAYER
NAME "layer_1"
DATA "c:\projects\ecw\sf5504.ecw"
TYPE RASTER
STATUS DEFAULT
END
END # Map File
-----Original Message-----
Sent: á 13 àå÷èåáø 2003 14:24
To: Omry Yadan
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Raster files problem
Omry,
You have to set STATUS DEFAULT to get a visible map. With STATUS ON, you
have to specify the layer explicitly in the URL
(.../mapserv?map=...&layer=...)
MapServer ignores non-existing raster files when it is compiled with the
--enable-ignore-missing-data flag (the default). I always compile with
--disable-ignore-missing-date for development, and only ignore missing
data for production.
Not seeing anything without an error is generally caused by:
- wrong extent
- status on instead of default
- incorrect raster file name
HTH
Jan
Omry Yadan wrote:
> I am trying to show an ECW raster file, and I am unable to get anything.
> I do not get an error, but the image I get is empty.
> A weird thing is, that even when I deliberately fuck up the file name, I
> don't get an error.
> It seems like the data is totally ignored...
> And idea?
> This is my map file:
> MAP
> NAME Sample
> STATUS ON
> SIZE 600 600
> PROJECTION
> "init=epsg:28354"
> END
> LAYER
> NAME "layer_1"
> TYPE RASTER
> MINSCALE 1
> MAXSCALE 25000
> STATUS ON
> END
> END # Map File
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
