[Mapserver-users] distance tool fixed?
Yewondwossen Assefa assefa at dmsolutions.ca
Mon Oct 13 17:47:52 EDT 2003
I just tried the version 1.2.0 from the download site and the distance
gets set to 0 between each time the distance tool is used.
  This issue has been adressed few months ago and should be available
inside the latest versions.
  Do other have similar problems ?
Later,
Guillermo Felipe wrote:
> Hi all,
> I´m been trying with the 1.2.0 (August 19, 2002) and
> (2003-04-02) versions of  the Rosa applet, but I didn´t have success
> with the accumulative distance problem....when I reselect the distance
> button or select another one, the initial distance is not 0.
> Do you know if the problem is fixed?
> I´m been reading some emails related and the README, so I don´t know if
> I´m doing something wrong:
> Change Log:
> Current version
> Version 1.2.1 (Feb 25, 2003):
> - Correct Bug with the mesuring tool.
> http://lists.maptools.org/pipermail/rosa-users/2002-June/000002.html
> Thanks in advance,
> guillermo
> pd: my code is:
> printf("<PARAM NAME=\"TB_BUT_dist_IMG\"
> VALUE=\"./images/tool_dist_1.gif\">\n");
> printf("<PARAM NAME=\"TB_BUT_dist_IMG_PR\"
> VALUE=\"./images/tool_dist_2.gif\">\n");
> printf("<PARAM NAME=\"TB_BUT_dist_HINT\" VALUE=\"Mida la distancia|entre
> dos puntos\">\n");
> printf("<PARAM NAME=\"TB_BUT_dist_INPUT\" VALUE=\"dist\">\n");
> printf("<PARAM NAME=\"TB_BUT_dist_NAME\" VALUE=\"CMD\">\n");
> printf("<PARAM NAME=\"TB_BUT_dist_VALUE\" VALUE=\"DISTANCE\">\n");
>  printf("<PARAM NAME=\"PIXEL_SIZE\"
> VALUE=\"%s\">\n",(($gpoMap->extent->maxx-$gpoMap->extent->minx)/$gpoMap->width));
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
