[Mapserver-users] distance tool fixed? historial?
Guillermo Felipe
gfmb at tutopia.com
Mon Oct 13 20:30:03 EDT 2003
Thanks for your attention.
After your email, I tested from other computer where I never used the rosa
applet and it worked!.
It seems to me that I had a problem with the temporary files. Always, I was
working with the old rosa applet in my xp server, so I changed its name to
rosa2.jar and it worked too.
Before change the name, I erased the temporary files and the historial, but
it didn´t fix the problem....Why?
Two more newbie questions:
+ How can I use the DIST_MSG parameter?...How can I call the distance value
in php?:
printf(<PARAM NAME="DIST_MSG" VALUE="Approximative distance: %s km">, ???);
+ How can I enable the ESC key with the distance tool?
Thanks again,
guillermo
----- Original Message -----
From: "Yewondwossen Assefa" <assefa at dmsolutions.ca>
To: "Guillermo Felipe" <gfmb at tutopia.com>
Cc: "mapserver users" <mapserver-users at lists.gis.umn.edu>;
<rosa-users at dmsolutions.ca>
Sent: Monday, October 13, 2003 4:47 PM
Subject: Re: [Mapserver-users] distance tool fixed?
> I just tried the version 1.2.0 from the download site and the distance
> gets set to 0 between each time the distance tool is used.
> This issue has been adressed few months ago and should be available
> inside the latest versions.
> Do other have similar problems ?
> Later,
> Guillermo Felipe wrote:
> > Hi all,
> > I´m been trying with the 1.2.0 (August 19, 2002) and
> > (2003-04-02) versions of the Rosa applet, but I didn´t have success
> > with the accumulative distance problem....when I reselect the distance
> > button or select another one, the initial distance is not 0.
> > Do you know if the problem is fixed?
> > I´m been reading some emails related and the README, so I don´t know if
> > I´m doing something wrong:
> > Change Log:
> > Current version
> > Version 1.2.1 (Feb 25, 2003):
> > - Correct Bug with the mesuring tool.
> > http://lists.maptools.org/pipermail/rosa-users/2002-June/000002.html
> > Thanks in advance,
> > guillermo
> > pd: my code is:
> > printf("<PARAM NAME=\"TB_BUT_dist_IMG\"
> > VALUE=\"./images/tool_dist_1.gif\">\n");
> > printf("<PARAM NAME=\"TB_BUT_dist_IMG_PR\"
> > VALUE=\"./images/tool_dist_2.gif\">\n");
> > printf("<PARAM NAME=\"TB_BUT_dist_HINT\" VALUE=\"Mida la distancia|entre
> > dos puntos\">\n");
> > printf("<PARAM NAME=\"TB_BUT_dist_INPUT\" VALUE=\"dist\">\n");
> > printf("<PARAM NAME=\"TB_BUT_dist_NAME\" VALUE=\"CMD\">\n");
> > printf("<PARAM NAME=\"TB_BUT_dist_VALUE\" VALUE=\"DISTANCE\">\n");
> > printf("<PARAM NAME=\"PIXEL_SIZE\"
VALUE=\"%s\">\n",(($gpoMap->extent->maxx-$gpoMap->extent->minx)/$gpoMap->wid
th));
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
