[Mapserver-users] distance tool fixed? historial?
Yewondwossen Assefa
assefa at dmsolutions.ca
Fri Oct 17 08:07:03 EDT 2003
Guillermo Felipe wrote:
> Hi,
> Thanks for your attention.
> After your email, I tested from other computer where I never used the rosa
> applet and it worked!.
> It seems to me that I had a problem with the temporary files. Always, I was
> working with the old rosa applet in my xp server, so I changed its name to
> rosa2.jar and it worked too.
> Before change the name, I erased the temporary files and the historial, but
> it didn´t fix the problem....Why?
> Two more newbie questions:
> + How can I use the DIST_MSG parameter?...How can I call the distance value
> in php?:
> printf(<PARAM NAME="DIST_MSG" VALUE="Approximative distance: %s km">, ???);
If you can outputing risa parameters from PHP, you do something like
this :
echo "<PARAM NAME=\"DIST_MSG\" VALUE=\"Approximative distance: %s km\">";
The distance value is not directly accessible through php.
> + How can I enable the ESC key with the distance tool?
Only double click is supported for now to stop the distance tool.
> Thanks again,
> guillermo
> ----- Original Message -----
> From: "Yewondwossen Assefa" <assefa at dmsolutions.ca>
> To: "Guillermo Felipe" <gfmb at tutopia.com>
> Cc: "mapserver users" <mapserver-users at lists.gis.umn.edu>;
> <rosa-users at dmsolutions.ca>
> Sent: Monday, October 13, 2003 4:47 PM
> Subject: Re: [Mapserver-users] distance tool fixed?
>>I just tried the version 1.2.0 from the download site and the distance
>>gets set to 0 between each time the distance tool is used.
>> This issue has been adressed few months ago and should be available
>>inside the latest versions.
>> Do other have similar problems ?
>>Later,
>>>Hi all,
>>>I´m been trying with the 1.2.0 (August 19, 2002) and
>>>(2003-04-02) versions of the Rosa applet, but I didn´t have success
>>>with the accumulative distance problem....when I reselect the distance
>>>button or select another one, the initial distance is not 0.
>>>Do you know if the problem is fixed?
>>>I´m been reading some emails related and the README, so I don´t know if
>>>I´m doing something wrong:
>>>Change Log:
>>>Current version
>>>Version 1.2.1 (Feb 25, 2003):
>>>- Correct Bug with the mesuring tool.
>>>http://lists.maptools.org/pipermail/rosa-users/2002-June/000002.html
>>>Thanks in advance,
>>>guillermo
>>>pd: my code is:
>>>printf("<PARAM NAME=\"TB_BUT_dist_IMG\"
>>>VALUE=\"./images/tool_dist_1.gif\">\n");
>>>printf("<PARAM NAME=\"TB_BUT_dist_IMG_PR\"
>>>VALUE=\"./images/tool_dist_2.gif\">\n");
>>>printf("<PARAM NAME=\"TB_BUT_dist_HINT\" VALUE=\"Mida la distancia|entre
>>>dos puntos\">\n");
>>>printf("<PARAM NAME=\"TB_BUT_dist_INPUT\" VALUE=\"dist\">\n");
>>>printf("<PARAM NAME=\"TB_BUT_dist_NAME\" VALUE=\"CMD\">\n");
>>>printf("<PARAM NAME=\"TB_BUT_dist_VALUE\" VALUE=\"DISTANCE\">\n");
>>> printf("<PARAM NAME=\"PIXEL_SIZE\"
> VALUE=\"%s\">\n",(($gpoMap->extent->maxx-$gpoMap->extent->minx)/$gpoMap->wid
> th));
>>Assefa Yewondwossen
>>Software Analyst
>>Email: assefa at dmsolutions.ca
>>http://www.dmsolutions.ca/
>>Phone: (613) 565-5056 (ext 14)
>>Fax: (613) 565-0925
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
