[Mapserver-users] Mapscript drawQuery() on big PostGIS layers doesn't work properly ?
Daniel Faivre daniel.faivre at camptocamp.com
Wed Oct 15 07:02:32 EDT 2003
Hello,
I've encountered serious difficulties with "big drawQueries" after a
queryByShape() on PostGIS layers, that do not happen with shapefiles.
Here is a sample php source code for problematics spatial queries with a
postgis layer: the
drawQuery() after a queryByShape() is not efficient enough (see sample
execution times commented in the code). Furthermore, tests shows that
replacing $sl_thm2 by a postgis layer lead to increased computing delays.
I assume that querying PostGIS layers in mapserver 4 is not efficient
enough ?
I've noticed comments in mapserver source code about an improved
algorithm, yet not implemented.
My PostGIS layer is properly spatial-indexed, and I've also tried to add
USING UNIQUE USING SRID="-1" without any improvement ...
_______________________________________________________________________________________________________
$Map = ms_newMapObj('my_mapfile.map');
$sl_thm1 = $Map->getlayerbyname('mybigpolygonslayer');      // A big
polygons PostGIS layer
$sl_thm2 = $Map->getlayerbyname(myquerylayer');                 // A
shapefile with one multiplygon
$sl_thm2->queryByRect($Map->extent);
 // Necessary for queryByFeatures
$res = $sl_thm1->queryByFeatures($sl_thm2->index);
$num_results = $sl_thm1->getNumResults();
echo "nb find: ".$num_results;               // about 2000 items founds,
in my sample
//$map_img = $Map->draw();                // 2  seconds to display the
result
$map_img = $Map->drawQuery();        // 160 to 260 seconds for a postgis
layer, 2  seconds for the same layer as shapefile !!!
$imgurl = $map_img->saveWebImage();
echo '<img src='.$imgurl.'>';
What can I do ??? Have you experienced same difficulties with big
postgis layers ? Any idea ? Workaround ?
Best regards,
Daniel Faivre
Ohceo - Camptocamp
+33 4 79 75 28 19
180 rue du Genevois
73000 Chambéry le Haut - FRANCE
