[Mapserver-users] Mapscript drawQuery() on big PostGIS layers
doesn't work properly ?
Paul Ramsey
pramsey at refractions.net
Wed Oct 15 10:56:12 EDT 2003
Indexes, indexes, indexes.
Do you have indexes on the columns of interest (spatial column,
unique identifier (or oid), and any attributes you are querying on?) if
you have not declared a unique identifier, then the oid will be
silently used, and you will need an oid index (create index tbl_oid_idx
on tbl (oid)).
Cost analysis. On large enough tables and complex enough queries,
cost analysis gets important. A PostGIS installation with the STATS
option enabled and stats calculated can do the "right thing" in query
planning which a naive installation completely screws up.
Paul
On Wednesday, October 15, 2003, at 04:02 AM, Daniel Faivre wrote:
> Hello,
> I've encountered serious difficulties with "big drawQueries" after a
> queryByShape() on PostGIS layers, that do not happen with shapefiles.
> Here is a sample php source code for problematics spatial queries with
> a postgis layer: the
> drawQuery() after a queryByShape() is not efficient enough (see sample
> execution times commented in the code). Furthermore, tests shows that
> replacing $sl_thm2 by a postgis layer lead to increased computing
> delays.
> I assume that querying PostGIS layers in mapserver 4 is not efficient
> enough ?
> I've noticed comments in mapserver source code about an improved
> algorithm, yet not implemented.
> My PostGIS layer is properly spatial-indexed, and I've also tried to
> add USING UNIQUE USING SRID="-1" without any improvement ...
> _______________________________________________________________________
> $Map = ms_newMapObj('my_mapfile.map');
> $sl_thm1 = $Map->getlayerbyname('mybigpolygonslayer'); // A big
> polygons PostGIS layer
> $sl_thm2 = $Map->getlayerbyname(myquerylayer'); // A
> shapefile with one multiplygon
> $sl_thm2->queryByRect($Map->extent);
> // Necessary for queryByFeatures
> $res = $sl_thm1->queryByFeatures($sl_thm2->index);
> $num_results = $sl_thm1->getNumResults();
> echo "nb find: ".$num_results; // about 2000 items
> founds, in my sample
> //$map_img = $Map->draw(); // 2 seconds to display the
> result
> $map_img = $Map->drawQuery(); // 160 to 260 seconds for a
> postgis layer, 2 seconds for the same layer as shapefile !!!
> $imgurl = $map_img->saveWebImage();
> echo '<img src='.$imgurl.'>';
> What can I do ??? Have you experienced same difficulties with big
> postgis layers ? Any idea ? Workaround ?
> Best regards,
> Daniel Faivre
> Ohceo - Camptocamp
> +33 4 79 75 28 19
> 180 rue du Genevois
> 73000 Chambéry le Haut - FRANCE
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
