[Mapserver-users] Upgraded 3.6 to 4.0 Windows binary and PIXMAP symbols, text-label colors no longer work correctly.
Martin, Daniel A
Daniel.A.Martin at erac.com
Wed Oct 15 15:56:45 EDT 2003
My problem is quite a bit different than those mentioned in the bug report. PIXMAP symbols cause no return at all from MapServer. Individual thumbnail images are not returned for the legend. If a map has the layer turned on, and a symbol should return in the image produced by MapServer, it also doesn't return anything (including the template contents itself). Basically, MapServer is choking when it attempts to use any PIXMAP symbol.
This problem continues when using PNG24.
I could offer the symbol and the definition I am using for it, if it would help.
-Dan
> -----Original Message-----
> From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> Sent: Wednesday, October 15, 2003 1:42 PM
> To: Martin, Daniel A
> Cc: Mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Upgraded 3.6 to 4.0 Windows binary and
> Martin, Daniel A wrote:
> > I still have the problem with PIXMAP symbols, if anyone has
> any information about that.
> There is a similar issue in bug 397, but it goes away when
> you switch to
> 24 bits output:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=397
> Daniel
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
