[Mapserver-users] Upgraded 3.6 to 4.0 Windows binary and PIXMAP
symbols, text-label colors no longer work correctly.
Daniel Morissette
morissette at dmsolutions.ca
Wed Oct 15 16:14:51 EDT 2003
Martin, Daniel A wrote:
> My problem is quite a bit different than those mentioned in the bug report. PIXMAP symbols cause no return at all from MapServer. Individual thumbnail images are not returned for the legend. If a map has the layer turned on, and a symbol should return in the image produced by MapServer, it also doesn't return anything (including the template contents itself). Basically, MapServer is choking when it attempts to use any PIXMAP symbol.
> This problem continues when using PNG24.
Did you set the class color? Even if the color is not used for a bitmap
symbol you need to set it, a class with no color is considered invisible
and is never drawn by MapServer 4.0.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
