[Mapserver-users] Upgraded 3.6 to 4.0 Windows binary and PIXMAP symbols, text-label colors no longer work correctly.
Martin, Daniel A Daniel.A.Martin at erac.com
Wed Oct 15 16:19:43 EDT 2003
Well, that fixed it.
The question I have now:  You said "...a class with no color is considered invisible and is never drawn by MapServer 4.0." Should MapServer bomb when a symbol with no color set is supposed to display?
Either way, that fixes my problems.  Thanks very much for your help, as always!
-Dan
> -----Original Message-----
> From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> Sent: Wednesday, October 15, 2003 3:15 PM
> To: Martin, Daniel A
> Cc: Mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Upgraded 3.6 to 4.0 Windows binary and
> Martin, Daniel A wrote:
> > My problem is quite a bit different than those mentioned in
> the bug report.  PIXMAP symbols cause no return at all from
> MapServer.  Individual thumbnail images are not returned for
> the legend.  If a map has the layer turned on, and a symbol
> should return in the image produced by MapServer, it also
> doesn't return anything (including the template contents
> itself).  Basically, MapServer is choking when it attempts to
> use any PIXMAP symbol.
> > This problem continues when using PNG24.
> Did you set the class color?  Even if the color is not used
> for a bitmap
> symbol you need to set it, a class with no color is
>   Daniel Morissette               morissette at dmsolutions.ca
>   DM Solutions Group              http://www.dmsolutions.ca/
