[Mapserver-users] install as not root
Edward Waithaka e_talis at yahoo.com
Fri Oct 17 07:23:22 EDT 2003
--0-1035932630-1066389802=:94505
Content-Type: text/plain; charset=us-ascii
Try this:
Add the following lines to the ld.conf.so file (you can locate it using 'locate' cmd)
- /usr/bin
- /usr/local/bin
(depends where the libproj.so lib file was stored after installation)
Then run the following command:> ldconfig
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
Content-Type: text/html; charset=us-ascii
<DIV>
<DIV>
<DIV>Try this:</DIV>
<DIV>Add the following lines to the ld.conf.so file (you can locate it using 'locate' cmd)</DIV>
<DIV>- /usr/bin</DIV>
<DIV>- /usr/local/bin</DIV>
<DIV>(depends where the libproj.so lib file was stored after installation)</DIV>
<DIV>Then run the following command:&gt; ldconfig</DIV></DIV></DIV><p><hr SIZE=1>
Do you Yahoo!?<br>
<a href="http://shopping.yahoo.com/?__yltc=s%3A150000443%2Cd%3A22708228%2Cslk%3Atext%2Csec%3Amail">The New Yahoo! Shopping</a> - with improved product search
--0-1035932630-1066389802=:94505--
