[Mapserver-users] Shapefile
Eduardo Spremolla edspremolla at Antel.com.uy
Fri Oct 17 08:14:43 EDT 2003
You can't convert a tiff to shape with gdaltindex.
The shape file created is only the index, and is used when your map is
tiled in many tiff.
You beter tray to get the outline of India in shp format from one of may
free data sources in the net. Search the archive for them.
LALO
El vie, 17 de 10 de 2003 a las 07:29, Mukta Telang escribió:
> Hi,
> I dont know abc of GIS ..so I have many questions.
> Here is the first one:
> I have a tiff image which is nothing but outline of a country.
> Since I want to be able to ZOOM/PAN query the image/map .. I *felt*
> CONVERTING it to shape file will help.
> So I did the following:
> gdaltindex india.tif
> And I got india.shp, india.dbf and india.shx files which I copied to my
> data directory.
> Am I on the right track?
> Then created a world file as follows:
> 2.93
> 0
> 0
> 6.50
> 65
> -25
> The resolution of image is 440X650 and one map unit is 5 degrees.
> The starting left hand corner (x,y) is (65 degrees E, 25 degrees N).
> min[x]=65 degrees East max[x]=95 degrees East
> min[y]=5 degrees North max[y]= 25 degrees North
> In the map configuration file I have given extent as
> EXTENT 0 0 440 650
> What is the next step?
> What is meant by LAYER of TYPE RASTER?
> Please help,
> Thanks,
> Mukta
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
