[Mapserver-users] using "polygonZ" shapefiles with Mapserver
Daniel Morissette morissette at dmsolutions.ca
Mon Oct 20 11:13:35 EDT 2003
JAQUEMET Clement DSIC BPSDC wrote:
> Hello,
> When we try to publish " polygonZ " shapefile data, mapserver return an
> error " msDrawShape(): General error message. Only polygon shapes can be
> drawn using a POLYGON layer definition. "
> Where can we find free utilities to convert polygonZ to polygon, or does
> it exist an extension for Mapserver to bypass this limit ?
You should be able to read those files via OGR.
i.e assuming you have built MapServer with OGR support, instead of this:
LAYER
   DATA "/path/to/shapefile"
END
use this:
LAYER
   CONNECTIONTYPE OGR
   CONNECTION "/path/to/shapefile.shp"
END
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
