[Mapserver-users] dynamic layer-help
Murat Isik
muratisik at megatek.com.tr
Tue Oct 21 06:54:21 EDT 2003
Hello Bjoern,
"For the pytonic way, I could send you some codesnippets as a
starting point"
That would be great since the ArcView method is one time and my point
plotting coordinates change by every time map is refreshed. It is like
everytime the webpage gets called from the server, this dynamic layer (or
some scripts like you mentioned) should go to the database and read the
latest coordinates. One other way I came up with since my last post if to
keep it simple and have the dynamic layer or script read coordinates from a
simple text file, and also have a second script, an unrelated-to-mapserver
one, running in cron of redhat 9 go and fetch data from mysql and write it
in the text file. That would be cool too.
This whole thing looks complex to me at the moment, since the most advanced
work I did about mapserver and web administration until now is to get the
Itasca demo working :)
Thanks for helping...
Have a nice day.
Murat Isik.
----- Original Message -----
To: "Murat Isik" <muratisik at megatek.com.tr>;
<mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, October 21, 2003 1:23 PM
Subject: Re: [Mapserver-users] dynamic layer-help
> Hi Murat,
> with ArcView you could do the following (tested with AV 3.1):
> 1. Export your data into a textfile
> 2. Choose Table->Add and select your Textfile
> 3. Choose View->Add Event Theme and select your txt-table, the X- and
> the Y-field.
> 4. Choose Theme->Convert to shapefile
> Voila! You're done!
> The other way would surely be to get phpmapscript, perlmapscript or
> pythonmapscript working on your machine. (I prefer the pythonic way...)
> Then you could query your MySQL database and build dynamic layers on the
> fly. For the pytonic way, I could send you some codesnippets as a
> starting point. The php- and perl-way is documented on the
> MapServer-Homepage and you will find lots of hints in the
> mailing-list-archive.
> Hope this helps,
> Bjoern.
> Am Dienstag, 21. Oktober 2003 11:37 schrieb Murat Isik:
> > Hello,
> > I have asked a similar question yesterday, but now I see that my
> > problem is far basical than what I thought.
> > What is the best way to create a dynamic layer? I have a city map
> > with several layers and I need to create a new dynamic layer which is
> > supposed to go and read coordinates from a mysql database and plot a
> > point accordingly. What is the starting point for such a task? Can I
> > do it in ArcView 3.x? I have searched a lot but did not understand
> > much since I dont know the basics.
> > Thanks
> > Have a nice day
> > Murat Isik
> small office solutions
> info at sosnetz.de - http://www.sosnetz.de
