[Mapserver-users] mapserv4 /tiff
robert fritz
robert-fritz at web.de
Tue Oct 21 09:10:25 EDT 2003
<html><base href="https://freemail.web.de/"/><style>p {margin: 0px}</style><body style='font-size:9pt; font-family:Verdana; font-family: Verdana' ><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">Hi,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">I have some grey-scale tiffs and some shape files. If I use mapserv366 on W2000/IIS and the tiffs and shapes are turned on, the shapes are colored as defined in the map file, for instance red or blue.<o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN!
: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">C:\Inetpub\Scripts>mapserv -v<o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">MapServer version 3.6.6 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OG<o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">R INPUT=GDAL INPUT=SHAPEFILE<o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-G!
/FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">If I use mapserv4 on W2000/IIS and the tiffs and shapes are turned on, the shapes are colored in grey only. Turning off the tiffs, the shapes are colored as defined in the map file. <o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="m!
so-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">C:\Inetpub\Scripts>mapserv4 -v<o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUP<o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">PORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE<o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style!
<o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">If I use mapserv4 and linux, I get the same result as using mapserv366 on win2000.<o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">linux:/s!
rv/www/cgi-bin # ./mapserv -v<o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=FREETYPE INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE<o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">linux:/srv/www/cgi-bin #<o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB!
oman">What can I do on mapserv4 / win2000?<o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">Thank you,<o:p></o:p></FONT></FONT></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">Robert<o:p></o:p></FONT></FONT></SPAN></P></body></html>
______________________________________________________________________________<br>Horoskop, Comics, VIPs, Wetter, Sport und Lotto im WEB.DE Screensaver1.2<br>Kostenlos downloaden: <A HREF="http://screensaver.web.de/?mc=021110"><B>http://screensaver.web.de/?mc=021110</B></A>
