[Mapserver-users] feature info request on win2k calls error message
Daniel Morissette
morissette at dmsolutions.ca
Tue Oct 21 14:01:11 EDT 2003
Were you using INFO_FORMAT=text/html by any chance? There was a bug in
4.0 (also in older 3.6.x versions) with text/html featureinfo output.
This has been fixed in the 4.0 CVS and should be part of the 4.0.1
release that should be available soon. If you can't wait for the
release then you can get the code from 'branch-4-0' branch in CVS.
Daniel
Till Adams wrote:
> Hi list,
> I have a problem with my (local) umn installation on a win2k machine:
> I request mapserver (UMN v4.0) as WMS via a WMS client.
> Whenever I query via FeatureInfoRequest I get a system-error message,
> which tells me, that mapserv.exe has caused an error and that I have to
> restart the program. I click on OK and after that the requested
> information comes up in my querytemplate as demanded - and I can proceed
> navigating through my map.
> I tried this on another win2k machine with the same client and the same
> version (I copied it fro the first machine) of mapserv.exe.
> I also updated all my win-stuff to whatever Bill said is the newest
> bugfix...
> Looking into the drwtsn.log tells me, that a kind of access violation
> occured and that the DrWatson.exe started directly after my mapserv.exe.
> Did anybody had this problem before or has any idea? I guess it has to
> do with my system and not wih the umn environment as it is.
> Thanks in advance,
> Till ;-)
