[Mapserver-users] How to view the query results in a separate frame.
    Michael Schulz
    mschulz at webgis.de
    Tue Oct 21 23:53:04 PDT 2003
Hi Maria,
i don't have a short snipplet that does it, it is all incorporated in
more javascript functionality, but a simple way to do it could be:
- catch the submission of your main mapserver form with:
<form name="mapserverform" ... onSubmit="chooseTarget();">
- check in chooseTarget() if mapserver mode is query, then we want to
redirect the result:
function chooseTarget() {
if (document.mapserverform.mode.value=="query")
   document.mapserverform.target="queryFrame";
document.mapserverform.submit();
When you've selected query mode and you query the map then your frame
named "queryFrame" will get the result. You should adjust your templates
accordingly. Keep in mind, that this procedure doesn't change your main
mapserver frame. You won't get a hilited query map with this simple
redirection.
HTH, Michael
m soto . wrote:
> hi michael!
> i read the answer you made to guillaume. i was wondering if you know any
> example in www to see that, or if you have got de javascript function to
> do that.
> i'm trying to redirect the result of the query to another frame, but i
> can't.
> thanks.
> Adeu. Maria.
> ----- Mensaje Original -----
> Remitente: Michael Schulz mschulz at webgis.de
> Destinatario: Guillaume MOCCAND moccand at ensg.ign.fr
> Fecha: Martes, Octubre 21, 2003 11:25am
> Asunto: Re: [Mapserver-users] How to view the query results in a
> separate frame.
>>Hi,
>>i am not sure if a howto exists on this topic.
>>One way is to use javascript in the query-template, that writes the
>>attribute results to your other frame when the page is loading (with
>>onLoad() funtion in the body-tag).
>>Another way is to redirect the result of the query to the other
>>frame.
>>Change the target (also via javascript) of your main mapserver form
>>to
>>your result frame for queries only. But then you don't have the
>>hilited
>>map in your main frame.
>>Cheers, Michael
>>Guillaume MOCCAND wrote:
>>>  Hi List !
>>>  i wonder how i could see the result of an identify query in a
>>diffrent frame
>>>  from the map frame ... i want to still see the map while the data
>>are displayed.
>>>  does anyone have a "howto" on this tips ?
>>>  thanks
>>>  Guillaume MOCCAND
>>>  _______________________________________________
>>>  Mapserver-users mailing list
>>>  Mapserver-users at lists.gis.umn.edu
>>>  http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>>Michael Schulz                                in medias res
>>Dipl.-Geologe                              Gesellschaft für
>>                                 Informationstechnologie mbH
>>                                      In den Weihermatten 66
>>                                       79108 Freiburg
>>                                      0761 55695-95 (Fax 96)
>>mschulz at webgis.de              www.webgis.de/www.zopecms.de
		                             79108 Freiburg
More information about the MapServer-users
