[Mapserver-users] using "polygonZ" shapefiles with Mapserver
JAQUEMET Clement DSIC BPSDC
Clement.JAQUEMET at interieur.gouv.fr
Wed Oct 22 04:13:16 EDT 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C39874.5853F492
Content-Type: text/plain;
charset="ISO-8859-1"
Content-Transfer-Encoding: quoted-printable
Hello Daniel,
Use the OGR connection is very a nice solution.
Thank
-----Message d'origine-----
De: Daniel Morissette [SMTP:morissette at dmsolutions.ca]
Date: lundi 20 octobre 2003 17:14
=C0: JAQUEMET Clement DSIC BPSDC
Cc: mapserver-users at lists.gis.umn.edu
Objet: Re: [Mapserver-users] using "polygonZ" shapefiles with
Mapserver
JAQUEMET Clement DSIC BPSDC wrote:
> Hello,
>=20
> When we try to publish " polygonZ " shapefile data, mapserver
return an=20
> error " msDrawShape(): General error message. Only polygon shapes
can be=20
> drawn using a POLYGON layer definition. "
>=20
> Where can we find free utilities to convert polygonZ to polygon,
or does=20
> it exist an extension for Mapserver to bypass this limit ?
>=20
You should be able to read those files via OGR.
i.e assuming you have built MapServer with OGR support, instead of
this:
LAYER
DATA "/path/to/shapefile"
END
use this:
LAYER
CONNECTIONTYPE OGR
CONNECTION "/path/to/shapefile.shp"
END
Daniel
--=20
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3DISO-8859-1">
<META NAME=3D"Generator" CONTENT=3D"MS Exchange Server version =
5.5.2656.60">
<TITLE>RE: [Mapserver-users] using "polygonZ" shapefiles with =
Mapserver</TITLE>
</HEAD>
<BODY>
<P><FONT SIZE=3D2 FACE=3D"Arial">Hello Daniel,</FONT>
</P>
<P><FONT SIZE=3D2 FACE=3D"Arial">Use the OGR connection is very a nice =
solution.</FONT>
</P>
<BR>
<BR>
<P><FONT SIZE=3D2 FACE=3D"Arial">Thank</FONT>
</P>
<UL>
<P><A NAME=3D"_MailData"><FONT SIZE=3D1 FACE=3D"Arial">-----Message =
d'origine-----</FONT></A>
<BR><B><FONT SIZE=3D1 =
FACE=3D"Arial">De: </FONT></B> <FONT SIZE=3D1 =
FACE=3D"Arial">Daniel Morissette =
[SMTP:morissette at dmsolutions.ca]</FONT>
<BR><B><FONT SIZE=3D1 FACE=3D"Arial">Date: </FONT></B> <FONT =
SIZE=3D1 FACE=3D"Arial">lundi 20 octobre 2003 17:14</FONT>
FACE=3D"Arial">=C0: </FONT></B> <FONT =
SIZE=3D1 FACE=3D"Arial">JAQUEMET Clement DSIC BPSDC</FONT>
FACE=3D"Arial">Cc: </FONT></B> <FONT SIZE=3D1 =
FACE=3D"Arial">mapserver-users at lists.gis.umn.edu</FONT>
<BR><B><FONT SIZE=3D1 FACE=3D"Arial">Objet: </FONT></B> <FONT =
SIZE=3D1 FACE=3D"Arial">Re: [Mapserver-users] using =
"polygonZ" shapefiles with Mapserver</FONT>
</P>
<P><FONT SIZE=3D2 FACE=3D"Arial">JAQUEMET Clement DSIC BPSDC =
wrote:</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">> Hello,</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">> </FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">> When we try to publish " =
polygonZ " shapefile data, mapserver return an </FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">> error " msDrawShape(): =
General error message. Only polygon shapes can be </FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">> drawn using a POLYGON layer =
definition. "</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">> Where can we find free utilities =
to convert polygonZ to polygon, or does </FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">> it exist an extension for =
Mapserver to bypass this limit ?</FONT>
</P>
<P><FONT SIZE=3D2 FACE=3D"Arial">You should be able to read those files =
via OGR.</FONT>
</P>
<P><FONT SIZE=3D2 FACE=3D"Arial">i.e assuming you have built MapServer =
with OGR support, instead of this:</FONT>
</P>
<P><FONT SIZE=3D2 FACE=3D"Arial">LAYER</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> DATA =
"/path/to/shapefile"</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> ...</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">END</FONT>
</P>
<P><FONT SIZE=3D2 FACE=3D"Arial">use this:</FONT>
</P>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> CONNECTIONTYPE =
OGR</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> CONNECTION =
"/path/to/shapefile.shp"</FONT>
</P>
<P><FONT SIZE=3D2 FACE=3D"Arial">Daniel</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">-- </FONT>
<BR><FONT SIZE=3D2 =
FACE=3D"Arial">---------------------------------------------------------=
---</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> Daniel =
Morissette &n=
bsp; morissette at dmsolutions.ca</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> DM Solutions =
Group &=
nbsp; <A HREF=3D"http://www.dmsolutions.ca/" =
TARGET=3D"_blank">http://www.dmsolutions.ca/</A></FONT>
---</FONT>
</P>
</UL>
</BODY>
</HTML>
------_=_NextPart_001_01C39874.5853F492--
