[Mapserver-users] map file permission denied
Nick Petersen-Bergeron
bergeron at zedxinc.com
Tue Oct 28 10:32:27 EST 2003
Well, apparently both image and points are some kind of reserved words that
you shouldn't use for layer names. I changed both of them, and now the map
opens fine. Thanks for the help.
Nick
At 04:53 PM 10/27/2003 -0500, Ed McNierney wrote:
>Nick -
>And what output does this command produce?
> ls -l /home/httpd/html/map/yield.map
> - Ed
>Ed McNierney
>President and Chief Mapmaker
>TopoZone.com
>ed at topozone.com
>-----Original Message-----
>From: Nick Petersen-Bergeron [mailto:bergeron at zedxinc.com]
>Sent: Monday, October 27, 2003 4:21 PM
>To: mapserver-users at lists.gis.umn.edu
>Subject: [Mapserver-users] map file permission denied
>I'm trying to open a basic mapfile, and I'm continually getting a
>mapfile
>permission denied error. The permissions on the mapfile are set to
>777. Here is the mapfile:
># Start of map file
>NAME YIELD
>STATUS ON
>SIZE 150 150
>EXTENT -91.1644 34.6098 -91.1306 34.6399
>UNITS DD
>SHAPEPATH "./"
>IMAGECOLOR 255 255 255
>## Start of web interface definition
>WEB
> IMAGEPATH "/home/httpd/html/dy_images/"
> IMAGEURL "/dy_images/"
>END
>SYMBOL
> NAME "circle"
> TYPE ellipse
> FILLED true
> POINTS
> 1 1
> END
>END
>LAYER
> NAME image
> TYPE raster
> DATA ""
> STATUS ON
> TEMPLATE void
> CLASS
> NAME "img"
> END
>END
>#LAYER
># NAME points
># TYPE point
># DATA ""
># STATUS ON
># TEMPLATE void
># CLASS
># NAME "dots"
># SIZE 5
># COLOR 255 0 0
># SYMBOL 'circle'
># END
>#END
>END # Map File
>My map object declaration line is simple, just this:
>my $map = new mapObj('/home/httpd/html/map/yield.map') or die("Unable to
>open mapfile. $!");
>This is the error: Unable to open mapfile. Permission denied
>Any ideas?
>BTW, thanks to those of you who helped with my dynamic class creation
>problem. The error turned out to be a silly mistake regarding a
>double-quote that should have been a single-quote.
>Developer
>ZedX Inc.
>369 Rolling Ridge Drive
>Bellefonte, PA. 16823
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
