[Mapserver-users] Problem with NCSUtil.dll
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Tue Oct 28 10:35:50 EST 2003
Hi Eduardo,
NCSUtil.dll is required to view ECW format files which I believe are
supported by GDAL. The easiest way to obtain the DLL file is simply to
go to http://www.earthetc.com and view some of the sample imagery on the
website on your NT machine. This will cause an ActiveX to be downloaded
onto your PC which will automatically install the NCSUtil.dll library
for you. Hopefully once this has been installed it will solve your
problem with mapserver.
Cheers,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> Eduardo Spremolla
> Sent: 28 October 2003 14:49
> To: mapserver
> Subject: [Mapserver-users] Problem with NCSUtil.dll
> I had a perfectly running mapserver installation on a win NT
> machine. It was ms366_gif_gdal_pg_wms.zip. Do to a crash the
> machine was reinstalled , and now I got this:
> The entry point for the procedure NCSFileTellStdIO can not be
> located in NCSUtill.dll
> I checked and there are no other copies of the dell floating around.
> Any clue?
> Thanks
> LALO
> Eduardo Spremolla <edspremolla at antel.com.uy>
> Antel I+D
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
