[Mapserver-users] no variable substitution with special characters?
Frieso ter Haseborg
ter-haseborg at sf-datentechnik.de
Wed Oct 29 05:10:12 EST 2003
isn't it possible to use special characters with the variable
substitution feature in mapfiles.
I've the following situtation:
In my mapfile I call a php for creating a dynamic layer:
LAYER
NAME "wms"
TEMPLATE test.html
STATUS ON
TYPE POLYGON
CONNECTION "http://my.ip/kmvims/kmvims.php?uid=%uid%&pwd=%pwd%
CONNECTIONTYPE WMS
For authorization purposes I use uid and pwd parameters. Everything
works fine unless I pass a pwd consisting of special characters, i.e.
characters with a ASCII value above ASCII 127 (HEX 7F). When pwd
contains one or more characters in the ASCII-range above 127 the layer
isn't called at all.
URL-encoding doesn't solve the problem. I need characters beyond ASCII
127 since the passwords passed are encrypted and I've no influence on
the encryption. It's just a passthrough given from a
client-server-application, all I want to do is retrieve the passwords
and check them against the database.
Any ideas about this? Is it a bug or an intended limitation?
TIA,
Frieso ter Haseborg
- Software Development -
S&F Datentechnik GmbH&Co.KG
Reimersstr. 41b
26789 Leer, Germany
