[Mapserver-users] Merge of shapefiles
Johan Antonsson johan at antonsson.com
Thu Oct 30 18:44:09 EST 2003
Thanks!
Does this mean I only need one mapfile for all my shape files?
Is there a good tutorial for the tiles feature?
TIA
/Johan
Johan Antonsson
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
woodbri at swoodbridge.com
Sent: den 30 oktober 2003 23:22
To: MapServer Users; Johan Antonsson
Subject: Re: [Mapserver-users] Merge of shapefiles
Johan,
This is exactly what tileindexes are for. So if you files are in
directory "data" do something like this:
find data -name "*.shp" > tile-input.txt
tile4ms tile-input.txt data-tiles
The next two lines will help with performance. I leave them up to the
reader to figure out :)
find data -name "*.shp" -exec shptree {} \;
shptree data-tiles
then in you mapfile
LAYER "data"
TILEINDEX "data-tiles"
And is should work! If you have a lot of different layers in "data"
then you will want to sort them into different tileindexes for each
layer.
-Steve W.
On 30 Oct 2003 at 22:45, Johan Antonsson wrote:
> Hi all,
> A couple of newbie questions that I'm having problem finding answers
to:
> I have a large set of shape files covering most of Sweden in 50 by 50
km
> squares (pieces). I would like to seamlessly generate maps within this
> dataset. Does MapServer have any support for this? I.e. to know when
its
> time to load the shape file for an adjacent map e.g. when the user
pans
> (between two squares). Or do I have to keep track of this myself?
> I have seen that MapServer has support for tiles but I haven't found
any
> good explanation what this really is. I know it's possible to generate
a
> tileindex shape file that will contain polygons for and links to a
> number of shape files but how can I make MapServer use this file? Can
it
> help me with the above problem? Can anyone point me to a good tiles
> information source?
> Thanks in advance
> /Johan
> Johan Antonsson
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
