[Mapserver-users] Help to configure Itasca : IIS setup needed
Stephen Clark stephen.clark at focus.ca
Fri Oct 31 11:28:35 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_001B_01C39F88.F9F61AD0
Content-Type: text/plain;
	charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Firat of all I am not a very good person to help you out with the IIS =
part.
You might try changing the type of map file output from JPG to PNG. =20
also, open up a command window in the folder that the mapserv.exe file =
is in and type 'mapserv -v' to check the results. =20
Determine if 'OUTPUT=3DJPEG' is in the listing.
You might also want to post the output to the list.
Also try to cc the list when you are posting as I may not always be able =
to respond right away.
hope this helps,
Stephen
  ----- Original Message -----=20
  To: stephen.clark at focus.ca=20
  Sent: Thursday, October 30, 2003 6:39 PM
  Subject: Re: [Mapserver-users] Help to configure Itasca
  I'm working with a map application that works on a WinXP machine, and =
I am trying to get the same one to work on Win2000 (network copy of all =
files). I can't seem to get mapserve to generate the temp image files, =
even though I've set up my permissions as the readme suggests. The =
scalebar properties show as:
  http://24.79.26.28/tmp/Tarinsb1067567778628.jpg, which is the correct =
location for the file, but no file is created there.
  Can you think of anything else that might cause this to happen? I have =
also restarted IIS numerous times after modifying the IIS configuration. =
As well, WinXP does not require Write permissions be given the temp =
directory.
  Thanks,
  Chris Storozuk
  Have you tried following the steps in this file?
  http://mapserver.gis.umn.edu/demo_readme.html
  From: "Felipe Amorelli" <famorelli at construtel-sti.com.br>
  To: "'Stephen Clark'" <stephen.clark at focus.ca>
  Sent: Saturday, October 18, 2003 10:12 AM
  Subject: RES: [Mapserver-users] Help to configure Itasca application
  Hi Stephen Clark,
  The file Demo10666470064001.png was not created in my machine  :(
  Thanks for the help,
  Felipe
  -----Mensagem original-----
  De: Stephen Clark [mailto:stephen.clark at focus.ca]
  Enviada em: segunda-feira, 20 de outubro de 2003 12:28
  Para: Felipe Amorelli
  Assunto: Re: [Mapserver-users] Help to configure Itasca application
  Try searching for the file
  "Demo10666470064001.png"
  To: <mapserver-users at lists.gis.umn.edu>
  Sent: Monday, October 20, 2003 5:07 AM
  Subject: Re: [Mapserver-users] Help to configure Itasca application
  Hello,
  Thanks for the information regarding the Gif2Png convertion, now the =
itasca
  application doesn=B4t have the gif error message anymore and the
  demo_init.html calls the demo.html
  but no image was displayed. if I get the properties of the image in =
the
  browser I see that they=B4re trying to get the image from a tmp/Demo
  10666470064001.png file, but this png file was not created in the /tmp
  Anybody knows what could be the cause of my problem ? I=B4m still =
making more
  tests here trying to determine the cause of this problem. Mapserver =
creates
  this temporary png file ?
  Thanks,
  Felipe
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1264" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Firat of all I am not a very good =
person to help=20
you out with the IIS part.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>You might try changing the type of map =
file output=20
from JPG to PNG.&nbsp; </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>also, open up a command window in the =
folder that=20
the mapserv.exe file is in and type 'mapserv -v' to check the =
results.&nbsp;=20
</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Determine if 'OUTPUT=3DJPEG' is in the=20
listing.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>You might also want to post the output =
to the=20
list.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Also try to cc the list when you are =
posting as I=20
may not always be able to respond right away.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>hope this helps,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Stephen</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
  <DIV style=3D"FONT: 10pt arial">----- Original Message ----- </DIV>
  <DIV=20
  style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"><B>From:</B>=20
  <A title=3Dcstorozuk at shaw.ca =
href=3D"mailto:cstorozuk at shaw.ca">Chris</A> </DIV>
  <DIV style=3D"FONT: 10pt arial"><B>To:</B> <A =
title=3Dstephen.clark at focus.ca=20
  href=3D"mailto:stephen.clark at focus.ca">stephen.clark at focus.ca</A> =
</DIV>
  <DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Thursday, October 30, =
2003 6:39=20
  PM</DIV>
  <DIV style=3D"FONT: 10pt arial"><B>Subject:</B> Re: [Mapserver-users] =
Help to=20
  configure Itasca</DIV>
  <DIV><BR></DIV>
  <DIV><FONT face=3DArial size=3D2>I'm working with a map application =
that works on=20
  a WinXP machine, and I am trying to get the same one to work on =
Win2000=20
  (network copy of all files). I can't seem to get mapserve to generate =
the temp=20
  image files, even though I've set up my permissions as the readme =
suggests.=20
  The scalebar properties show as:</FONT></DIV>
  <DIV><FONT face=3DArial><A=20
  href=3D"http://24.79.26.28/tmp/Tarinsb1067567778628.jpg"><FONT=20
size=3D2>http://24.79.26.28/tmp/Tarinsb1067567778628.jpg</FONT></A><FONT =
  size=3D2>, which is the correct location for the file, but no file is =
created=20
  there.</FONT></FONT></DIV>
  <DIV><FONT face=3DArial size=3D2>Can you think of anything else that =
might cause=20
  this to happen? I have also restarted IIS numerous times after =
modifying the=20
  IIS configuration. As well, WinXP does not require Write permissions =
be given=20
  the temp directory.</FONT></DIV>
  <DIV><FONT face=3DArial size=3D2>Thanks,</FONT></DIV>
  <DIV><FONT face=3DArial size=3D2>Chris Storozuk</FONT></DIV>
  <DIV><FONT face=3DArial></FONT>&nbsp;</DIV>
  <DIV><FONT face=3DArial>----- Original Message ----- </FONT></DIV>
  <DIV><FONT face=3DArial>Have you tried following the steps in this=20
  file?<BR><BR><A=20
href=3D"http://mapserver.gis.umn.edu/demo_readme.html">http://mapserver.g=
is.umn.edu/demo_readme.html</A><BR><BR><BR><BR>-----=20
  Original Message ----- <BR>From: "Felipe Amorelli"=20
  &lt;famorelli at construtel-sti.com.br&gt;<BR>To: "'Stephen Clark'"=20
  &lt;stephen.clark at focus.ca&gt;<BR>Sent: Saturday, October 18, 2003 =
10:12=20
  AM<BR>Subject: RES: [Mapserver-users] Help to configure Itasca=20
  application<BR><BR><BR>Hi Stephen Clark,<BR><BR>The file=20
  Demo10666470064001.png was not created in my machine&nbsp; =
:(<BR><BR>Thanks=20
  for the help,<BR>Felipe<BR><BR>-----Mensagem original-----<BR>De: =
Stephen=20
  Clark [<A=20
href=3D"mailto:stephen.clark at focus.ca">mailto:stephen.clark at focus.ca</A>]=
<BR>Enviada=20
  em: segunda-feira, 20 de outubro de 2003 12:28<BR>Para: Felipe=20
  Amorelli<BR>Assunto: Re: [Mapserver-users] Help to configure Itasca=20
  application<BR><BR><BR>Try searching for the=20
  file<BR><BR>"Demo10666470064001.png"<BR><BR><BR><BR><BR><BR>----- =
Original=20
  &lt;famorelli at construtel-sti.com.br&gt;<BR>To:=20
  &lt;mapserver-users at lists.gis.umn.edu&gt;<BR>Sent: Monday, October 20, =
2003=20
  5:07 AM<BR>Subject: Re: [Mapserver-users] Help to configure Itasca=20
  application<BR><BR><BR>Hello,<BR><BR>Thanks for the information =
regarding the=20
  Gif2Png convertion, now the itasca<BR>application doesn=B4t have the =
gif error=20
  message anymore and the<BR>demo_init.html calls the demo.html<BR>but =
no image=20
  was displayed. if I get the properties of the image in the<BR>browser =
I see=20
  that they=B4re trying to get the image from a =
tmp/Demo<BR>10666470064001.png=20
  file, but this png file was not created in the /tmp<BR><BR>Anybody =
knows what=20
  could be the cause of my problem ? I=B4m still making more<BR>tests =
here trying=20
  to determine the cause of this problem. Mapserver creates<BR>this =
temporary=20
  png file =
?<BR><BR>Thanks,<BR>Felipe<BR></DIV></BLOCKQUOTE></FONT></BODY></HTML>
------=_NextPart_000_001B_01C39F88.F9F61AD0--
