[Mapserver-users] MUM website "Contributed Utilities
Christopher R. Thorne
thorne at dmsolutions.ca
Fri Oct 31 16:49:59 EST 2003
This is a multi-part message in MIME format.
--------------060101050405080102060705
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
Hello all,
It has been brought to my attention that under the user contributed
utilities on Mapserver website:
http://mapserver.gis.umn.edu/contributed.html
that there is no Textpad highlighter syntax file map.sym. This would be
very useful for TextPad users, just like the UltraEdit syntax
highlighter found on this list.
Can someone direct me to the person incharge on the MUN Mapserver
website, so that I can pass this along?
Thanks inadvance,
Chris
GIS Specialist,
DM Solutions Group Inc.
http://www.dmsolutions.ca
email: thorne at dmsolutions.ca
Phone: (613) 565-5056 ext.22
Fax : (613) 565-0925
name="map.syn"
Content-Disposition: inline;
filename="map.syn"
; Rudimentary syntax file for Mapserver .MAP file
; Started by:
; Matt Wilkie * Whitehorse, Yukon, Canada * 20-Oct-2k
; this works best when used in conjunction with the preferences
; specified in MAPSERVER_SYN.REG (mostly to set up the colours).
; Keywords are duplicated. One set is in upper case, the other in lower.
; (allows different colour based on case.) If the syntax parser is a
; little slow on your system it may help to delete the duplicates and
; turn IgnoreCase to Yes.
; Updated and extended [date] * [name]:
; 20-Oct-2k * matt.wilkie at gov.yk.ca
C=1
[Syntax]
Namespace1 = 6
IgnoreCase = No
InitKeyWordChars = A-Za-z
BracketChars = []
OperatorChars =
PreprocStart =
SyntaxStart =
SyntaxEnd =
CommentStart =
CommentEnd =
SingleComment = #
SingleCommentCol =
SingleCommentAlt = #
SingleCommentColAlt = 1
StringStart = "
StringEnd = "
StringEsc =
CharStart = '
CharEnd = '
CharEsc =
[Keywords 1]
; Major keywords which start/end code blocks
END
LAYER
LEGEND
NAME
REFERENCE
SCALEBAR
WEB
; Map Objects
EXTENT
FONTSET
IMAGECOLOR
INTERLACE
LAYER
LEGEND
LINESET
MARKERSET
NAME
QUERYMAP
REFERENCE
SCALE
SCALEBAR
SHADESET
SHAPEPATH
SIZE
STATUS
TILE
TRANSPARENT
UNITS
WEB
; Label Objects
ANTIALIAS
BUFFER
BACKGROUNDCOLOR
BACKGROUNDSHADOWCOLOR
BACKGROUNDSHADOWSIZE
COLOR
FONT
FORCE
MINDISTANCE
MINFEATURESIZE
MAXSIZE
MINSIZE
OFFSET
OUTLINECOLOR
PARTIALS
POSITION
SIZE
TYPE
WRAP
; Layer Objects
CLASSITEM
CONNECTION
CONNECTIONTYPE
DATA
DESCRIPTION
FEATURE
FOOTER
GROUP
HEADER
LABELANGLEITEM
LABELCACHE
LABELITEM
LABELMAXSCALE
LABELMINSCALE
LABELSIZEITEM
MAXFEATURES
MAXSCALE
MINSCALE
NAME
POSTLABELCACHE
QUERY
QUERYITEM
SYMBOLSCALE
STATUS
TILEINDEX
TILEITEM
TOLERANCE
TOLERANCEUNITS
TRANSFORM
TYPE
; Class Objects
COLOR
EXPRESSION
LABEL
MAXSIZE
MINSIZE
NAME
OUTLINECOLOR
SIZE
SYMBOL
TEXT
; Feature Object
POINTS
CLASS
TEXT
; Legend Object
EMBED
IMAGECOLOR
LABEL
OUTLINECOLOR
POSITION
SIZE
SPACING
STATUS
; Query Objects
EXPRESSION
JOIN
TEMPLATE
; Query Map Objects
COLOR
SIZE
STYLE
; Join Object
FROM
NAME
TABLE
TEMPLATE
TO
TYPE
; Reference Object
COLOR
EXTENT
OUTLINECOLOR
SIZE
STATUS
; Scalebar Object
BACKGROUNDCOLOR
COLOR
IMAGECOLOR
INTERVALS
LAVEL
OUTLINECOLOR
POSITION
POSTLABELCACHE
SIZE
STATUS
STYLE
UNITS
; Web Object
EMPTY
ERROR
FOOTER
HEADER
IMAGEPATH
IMAGEURL
LOG
MAXSCALE
MAXTEMPLATE
MINSCALE
MINTEMPLATE
TEMPLATE
[Keywords 2]
; Minor keywords which you don't want to stand out so much
; Map Objects
extent
fontset
imagecolor
interlace
layer
legend
lineset
markerset
name
querymap
reference
scale
scalebar
shadeset
shapepath
size
status
tile
transparent
units
web
; Label Objects
antialias
buffer
backgroundcolor
backgroundshadowcolor
backgroundshadowsize
color
font
force
mindistance
minfeaturesize
maxsize
minsize
offset
outlinecolor
partials
position
size
type
wrap
; Layer Objects
classitem
connection
connectiontype
data
description
feature
footer
group
header
labelangleitem
labelcache
labelitem
labelmaxscale
labelminscale
labelsizeitem
maxfeatures
maxscale
minscale
name
postlabelcache
query
queryitem
symbolscale
status
tileindex
tileitem
tolerance
toleranceunits
transform
type
; Class Objects
color
expression
label
maxsize
minsize
name
outlinecolor
size
symbol
text
; Feature Object
points
class
text
; Legend Object
embed
imagecolor
label
outlinecolor
position
size
spacing
status
; Query Objects
expression
join
template
; Query Map Objects
color
size
style
; Join Object
from
name
table
template
to
type
; Reference Object
color
extent
outlinecolor
size
status
; Scalebar Object
backgroundcolor
color
imagecolor
intervals
lavel
outlinecolor
position
postlabelcache
size
status
style
units
; Web Object
empty
error
footer
header
imagepath
imageurl
log
maxscale
maxtemplate
minscale
mintemplate
template
[Keywords 6]
; Values
auto
dd
default
false
feet
giant
hilite
inches
kilometers
large
lc
ll
local
lr
medium
meters
miles
multiple
normal
off
on
pixels
queryonly
sde
selected
single
small
tiny
true
uc
ul
ur
polygon
polyline
point
raster
--------------060101050405080102060705--
