[Mapserver-users] Php Mapscript with 500 layers, 1000 classes ??
Stephen Clark stephen.clark at focus.ca
Fri Oct 31 19:23:20 EST 2003
Would DM Solutions be willing to post a PHP Mapscript version with 500
layers, 1000 classes?
P.H.P version 4.3.2 Mapserver 4.0.0
If not could you post a description of how to compile php mapscript.  The
Wiki and online docs are a little sketchy. Or perhaps someone could update
the docs for php mapsript to version 4.0.0 and php 4.3.2.
thanks,
Stephen
----- Original Message -----
From: "Yewondwossen Assefa" <assefa at dmsolutions.ca>
To: "Stephen Clark" <stephen.clark at focus.ca>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Thursday, October 30, 2003 8:03 AM
Subject: Re: [Mapserver-users] Php Mapscript Specs requested
> It should contain the default settings that come with the mapserver
> source code which is 100 layers, 256 classes.
> Unless It is a specif build done for someone with values boosted, this
> should always be the case. Usually the name of the zip file should
> indicate that (ex : mapserver-4.1dev-win32-php4.3.2_256layers.zip build
> done supporting 256 layers) and sometimes the README that comes with the
> zip contains this specific changes done (but I sometimes forget to
> update the readme).
> Later,
> Stephen Clark wrote:
> > Hi all ,
> > Here is the PHP mapscript I downloaded from DM Solutions:
> > MapScript
> >       MapServer Version  MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG
> > OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ
> > SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> > SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=POSTGIS INPUT=OGR
INPUT=GDAL
> > INPUT=SHAPEFILE
> >       PHP MapScript Version  ($Revision: 1.177 $ $Date: 2003/07/30
19:01:31
> > Could someone tell me how many layers, classes and color objects that
are
> > supported with this version?
> > thanks,
> > Stephen
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax:   (613) 565-0925
