[Mapserver-users] Php Mapscript Specs requested
Yewondwossen Assefa assefa at dmsolutions.ca
Thu Oct 30 11:03:10 EST 2003
It should contain the default settings that come with the mapserver
source code which is 100 layers, 256 classes.
Unless It is a specif build done for someone with values boosted, this
should always be the case. Usually the name of the zip file should
indicate that (ex : mapserver-4.1dev-win32-php4.3.2_256layers.zip build
done supporting 256 layers) and sometimes the README that comes with the
zip contains this specific changes done (but I sometimes forget to
update the readme).
Later,
Stephen Clark wrote:
> Hi all ,
> Here is the PHP mapscript I downloaded from DM Solutions:
> MapScript
>       MapServer Version  MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG
> OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
>       PHP MapScript Version  ($Revision: 1.177 $ $Date: 2003/07/30 19:01:31
> Could someone tell me how many layers, classes and color objects that  are
> supported with this version?
> thanks,
> Stephen
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
