[Mapserver-users] Link
Pericles Nacionales
nacional at cbs.umn.edu
Thu Apr 1 18:29:53 EST 2004
It should work... if I understand what you're doing.
do something like this in your query template:
<a href="[your_link_attribute]">[your_link_attribute] or
[some_other_descriptive_attribute]</a>
Is that what you're trying to do? It should work if you have your
image/file in the right directory (and that directory is web accessible
with read privilege).
Cheers!
-Perry N.
On Fri, 2 Apr 2004, Litea Biukoto wrote:
> Bula
> I'm trying to find a way to link a map object to a(n image) file or url.
> I'd be glad for any workarounds. Thought that I could get away with having
> a LINK attribute in my table/file then accessing the link through the query
> function. This does not appear to work, all you see are the other
> attributes and path but no active link.
> Any ideas?
> TIA
> Litea
> Litea Biukoto
> SOPAC South Pacific Applied Geoscience Commission
> Postal Address: Private Mail Bag, GPO, Suva, Fiji Islands
> Street Address: Mead Road, Nabua, Fiji Islands
> Tel: +679 338-1377 Fax: +679 337-0040
> E-mail: litea at sopac.org <mailto:litea at sopac.org>
> Web site: http://www.sopac.org.fj/ <http://www.sopac.org.fj/> ,
> http://map.sopac.org/ <http://map.sopac.org/>
> Note that the gateway to our mail server limits the size of inward and
> outward messages with attachments to 1.5MB. If you need to send or receive
> larger messages apply compression, convert to PDF files or logically split.
> This e-mail is intended for its named recipients only. The author is no
> longer responsible if you forward this e-mail to other parties. The views
> expressed in this e-mail may not necessarily be the views of SOPAC.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
