[Mapserver-users] Stile problem with SWF and fdb fonts
Stephen Woodbridge woodbri at swoodbridge.com
Wed Apr 7 08:38:47 EDT 2004
I ran into the problem of php_mapscript.so and php_ming.so not being
compatible and I believe this problem is related to the fact that one or
both of these is using a private copy of the libpng and one is using the
system version. I think I wrote a bug on this, you might want to check
bugzilla.
-Steve W.
mapserver at no-log.org wrote:
> Hi Ray,
> I've partially solved the problem.
> Your font type must be defined as truetype and not bitmap when using fdb
> fonts.
> LABEL
>   TYPE truetype
>   FONT "your_font"
> END
> If you use shp2img, same issue ?
> shp2img -m your_mapfile.map -o test.swf
> I've experienced some crashs when rendering fonts with ming.
> I can't use php mapscript module and php ming module at the same time.
> (under linux php_mapscript.so and php_ming.so). All works fine but when i
> try to render an swf object which uses fonts using the ming module i get
> an internal server error.
> I'll check the latest release from cvs, i've reported the bug it is maybe
> solved ;)
> I expect it will help
> Christophe Beveraggi
>>I am having this same issue. I'm running mapserver 4.0.1 with ming v0.3a
>>on
>>a Solaris 8 (sparc) box. I was getting an internal server error with 4.0.1
>>then I switched to the latest nightly build and no more internal errors.
>>But
>>I don't get any fonts showing up at all. Also I am using .fdb fonts
>>directly
>>from the ming site. Everything else seems to be working just fine all the
>>layers are displayed and look great I just don't have any labels...
>>Has anyone run into this same problem? or better yet resolved it?....I'm
>>not
>>sure what else to try at this point since I'm no longer recieving any
>>error
>>messages at all....any help would be appreciated...
>>Ray,
>>OUTPUTFORMAT
>>  NAME swf
>>  DRIVER "SWF"
>>  MIMETYPE "application/x-shockwave-flash"
>>  EXTENSION "swf"
>>  IMAGEMODE PC256
>>  FORMATOPTION "OUTPUT_MOVIE=MULTIPLE FULL_RESOLUTION=FALSE"
>>END
>>  LABELITEM "name"
>>  CLASS
>>    MAXSCALE 10000
>>    NAME 'Local Road'
>>    COLOR 131 132 125
>>    SYMBOL 'circle'
>>    SIZE 2
>>    LABEL
>>              TYPE BITMAP
>>		  ANTIALIAS FALSE
>>		  ANGLE AUTO
>>              POSITION uc
>>              FONT "sans-fdb"
>>              COLOR 0 30 50 #51 51 51
>>              OUTLINECOLOR 255 255 255
>>              SIZE SMALL
>>              PARTIALS FALSE
>>              BUFFER 1
>>    END
>>  END
>>-----Original Message-----
>>From: mapserver-users-admin at lists.gis.umn.edu
>>[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of
>>Sent: Friday, March 19, 2004 10:40 AM
>>To: mapserver-users at lists.gis.umn.edu
>>Subject: [Mapserver-users] Stile problem with SWF and fdb fonts
>>Hi,
>>First, s/Stile/Still in subject sorry ;)
>>New strange thing, all layers are rendered correctly with
>>OUTPUT_MOVIE=multiple using fdb fonts when i use shp2img with my mapfile.
>>Always internal server error using php_mapscript and apache with multiple
>>swf layers rendering, and no problem with unique layer rendering
>>(OUTPUT_MOVIE=single).
>>Any help would be appreciated :)
>>Sample of the layer:
>>LAYER
>>  NAME "Regions"
>>  TYPE line
>>  DATA "lim_adm_france_dom"
>>  STATUS on
>>  DEBUG on
>>  CLASSITEM 'NATURE'
>>  LABELITEM 'ID_GEOFLA'
>>   CLASS
>>      DEBUG on
>>      NAME 'regions'
>>      EXPRESSION ('[NATURE]' eq 'Limite de région')
>>      SIZE 3
>>      COLOR 255 0 0
>>      SYMBOL "circle"
>>      LABEL
>>       TYPE bitmap
>>       FONT "verdana"
>>       COLOR 0 0 0
>>       SIZE 12
>>       MAXSIZE 18
>>       POSITION CC
>>       ANGLE AUTO
>>       BUFFER 2
>>      END
>>   END
>>   PROJECTION
>>    "init=epsg:2154"
>>   END
>>  TOLERANCE 5
>>END
>>Thanks
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
