[Mapserver-users] Stile problem with SWF and fdb fonts
mapserver at no-log.org
Wed Apr 7 09:44:02 EDT 2004
My problem only appears when i try to render fonts with ming.
Thanks a lot, i will check your bug report :)
Christophe
> I ran into the problem of php_mapscript.so and php_ming.so not being
> compatible and I believe this problem is related to the fact that one or
> both of these is using a private copy of the libpng and one is using the
> system version. I think I wrote a bug on this, you might want to check
> bugzilla.
> -Steve W.
> mapserver at no-log.org wrote:
>> Hi Ray,
>> I've partially solved the problem.
>> Your font type must be defined as truetype and not bitmap when using fdb
>> fonts.
>> LABEL
>> TYPE truetype
>> FONT "your_font"
>> END
>> If you use shp2img, same issue ?
>> shp2img -m your_mapfile.map -o test.swf
>> I've experienced some crashs when rendering fonts with ming.
>> I can't use php mapscript module and php ming module at the same time.
>> (under linux php_mapscript.so and php_ming.so). All works fine but when
>> i
>> try to render an swf object which uses fonts using the ming module i get
>> an internal server error.
>> I'll check the latest release from cvs, i've reported the bug it is
>> maybe
>> solved ;)
>> I expect it will help
>> Christophe Beveraggi
>>>I am having this same issue. I'm running mapserver 4.0.1 with ming v0.3a
>>>on
>>>a Solaris 8 (sparc) box. I was getting an internal server error with
>>> 4.0.1
>>>then I switched to the latest nightly build and no more internal errors.
>>>But
>>>I don't get any fonts showing up at all. Also I am using .fdb fonts
>>>directly
>>>from the ming site. Everything else seems to be working just fine all
>>> the
>>>layers are displayed and look great I just don't have any labels...
>>>Has anyone run into this same problem? or better yet resolved it?....I'm
>>>not
>>>sure what else to try at this point since I'm no longer recieving any
>>>error
>>>messages at all....any help would be appreciated...
>>>Ray,
>>>OUTPUTFORMAT
>>> NAME swf
>>> DRIVER "SWF"
>>> MIMETYPE "application/x-shockwave-flash"
>>> EXTENSION "swf"
>>> IMAGEMODE PC256
>>> FORMATOPTION "OUTPUT_MOVIE=MULTIPLE FULL_RESOLUTION=FALSE"
>>>END
>>> LABELITEM "name"
>>> CLASS
>>> MAXSCALE 10000
>>> NAME 'Local Road'
>>> COLOR 131 132 125
>>> SYMBOL 'circle'
>>> SIZE 2
>>> LABEL
>>> TYPE BITMAP
>>> ANTIALIAS FALSE
>>> ANGLE AUTO
>>> POSITION uc
>>> FONT "sans-fdb"
>>> COLOR 0 30 50 #51 51 51
>>> OUTLINECOLOR 255 255 255
>>> SIZE SMALL
>>> PARTIALS FALSE
>>> BUFFER 1
>>> END
>>> END
>>>-----Original Message-----
>>>From: mapserver-users-admin at lists.gis.umn.edu
>>>[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of
>>>Sent: Friday, March 19, 2004 10:40 AM
>>>To: mapserver-users at lists.gis.umn.edu
>>>Subject: [Mapserver-users] Stile problem with SWF and fdb fonts
>>>Hi,
>>>First, s/Stile/Still in subject sorry ;)
>>>New strange thing, all layers are rendered correctly with
>>>OUTPUT_MOVIE=multiple using fdb fonts when i use shp2img with my
>>> mapfile.
>>>Always internal server error using php_mapscript and apache with
>>> multiple
>>>swf layers rendering, and no problem with unique layer rendering
>>>(OUTPUT_MOVIE=single).
>>>Any help would be appreciated :)
>>>Sample of the layer:
>>>LAYER
>>> NAME "Regions"
>>> TYPE line
>>> DATA "lim_adm_france_dom"
>>> STATUS on
>>> DEBUG on
>>> CLASSITEM 'NATURE'
>>> LABELITEM 'ID_GEOFLA'
>>> CLASS
>>> DEBUG on
>>> NAME 'regions'
>>> EXPRESSION ('[NATURE]' eq 'Limite de région')
>>> SIZE 3
>>> COLOR 255 0 0
>>> SYMBOL "circle"
>>> LABEL
>>> TYPE bitmap
>>> FONT "verdana"
>>> COLOR 0 0 0
>>> SIZE 12
>>> MAXSIZE 18
>>> POSITION CC
>>> ANGLE AUTO
>>> BUFFER 2
>>> END
>>> END
>>> PROJECTION
>>> "init=epsg:2154"
>>> END
>>> TOLERANCE 5
>>>END
>>>Thanks
>>>_______________________________________________
>>>Mapserver-users mailing list
>>>Mapserver-users at lists.gis.umn.edu
>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
