[Mapserver-users] Stile problem with SWF and fdb fonts
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 7 15:05:19 EDT 2004
OK, I didn't remember this exactly right. But bug 370
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=370
is what I was thinking of. I was pdflib not ming that I ran into this
problem with. That said, you should read the bug anyway and look ad how
we used ldd to diagnose where the library conflict came from. You might
be able to use the same trick to get a better handle on your exact problem.
-Steve W.
mapserver at no-log.org wrote:
> My problem only appears when i try to render fonts with ming.
> Thanks a lot, i will check your bug report :)
> Christophe
>>I ran into the problem of php_mapscript.so and php_ming.so not being
>>compatible and I believe this problem is related to the fact that one or
>>both of these is using a private copy of the libpng and one is using the
>>system version. I think I wrote a bug on this, you might want to check
>>bugzilla.
>>-Steve W.
>>>Hi Ray,
>>>I've partially solved the problem.
>>>Your font type must be defined as truetype and not bitmap when using fdb
>>>fonts.
>>>LABEL
>>> TYPE truetype
>>> FONT "your_font"
>>>END
>>>If you use shp2img, same issue ?
>>>shp2img -m your_mapfile.map -o test.swf
>>>I've experienced some crashs when rendering fonts with ming.
>>>I can't use php mapscript module and php ming module at the same time.
>>>(under linux php_mapscript.so and php_ming.so). All works fine but when
>>>i
>>>try to render an swf object which uses fonts using the ming module i get
>>>an internal server error.
>>>I'll check the latest release from cvs, i've reported the bug it is
>>>maybe
>>>solved ;)
>>>I expect it will help
>>>Christophe Beveraggi
>>>>I am having this same issue. I'm running mapserver 4.0.1 with ming v0.3a
>>>>on
>>>>a Solaris 8 (sparc) box. I was getting an internal server error with
>>>>4.0.1
>>>>then I switched to the latest nightly build and no more internal errors.
>>>>But
>>>>I don't get any fonts showing up at all. Also I am using .fdb fonts
>>>>directly
>>>>from the ming site. Everything else seems to be working just fine all
>>>>the
>>>>layers are displayed and look great I just don't have any labels...
>>>>Has anyone run into this same problem? or better yet resolved it?....I'm
>>>>not
>>>>sure what else to try at this point since I'm no longer recieving any
>>>>error
>>>>messages at all....any help would be appreciated...
>>>>Ray,
>>>>OUTPUTFORMAT
>>>> NAME swf
>>>> DRIVER "SWF"
>>>> MIMETYPE "application/x-shockwave-flash"
>>>> EXTENSION "swf"
>>>> IMAGEMODE PC256
>>>> FORMATOPTION "OUTPUT_MOVIE=MULTIPLE FULL_RESOLUTION=FALSE"
>>>>END
>>>> LABELITEM "name"
>>>> CLASS
>>>> MAXSCALE 10000
>>>> NAME 'Local Road'
>>>> COLOR 131 132 125
>>>> SYMBOL 'circle'
>>>> SIZE 2
>>>> LABEL
>>>> TYPE BITMAP
>>>> ANTIALIAS FALSE
>>>> ANGLE AUTO
>>>> POSITION uc
>>>> FONT "sans-fdb"
>>>> COLOR 0 30 50 #51 51 51
>>>> OUTLINECOLOR 255 255 255
>>>> SIZE SMALL
>>>> PARTIALS FALSE
>>>> BUFFER 1
>>>> END
>>>> END
>>>>-----Original Message-----
>>>>From: mapserver-users-admin at lists.gis.umn.edu
>>>>[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of
>>>>Sent: Friday, March 19, 2004 10:40 AM
>>>>To: mapserver-users at lists.gis.umn.edu
>>>>Subject: [Mapserver-users] Stile problem with SWF and fdb fonts
>>>>Hi,
>>>>First, s/Stile/Still in subject sorry ;)
>>>>New strange thing, all layers are rendered correctly with
>>>>OUTPUT_MOVIE=multiple using fdb fonts when i use shp2img with my
>>>>mapfile.
>>>>Always internal server error using php_mapscript and apache with
>>>>multiple
>>>>swf layers rendering, and no problem with unique layer rendering
>>>>(OUTPUT_MOVIE=single).
>>>>Any help would be appreciated :)
>>>>Sample of the layer:
>>>>LAYER
>>>> NAME "Regions"
>>>> TYPE line
>>>> DATA "lim_adm_france_dom"
>>>> STATUS on
>>>> DEBUG on
>>>> CLASSITEM 'NATURE'
>>>> LABELITEM 'ID_GEOFLA'
>>>> CLASS
>>>> DEBUG on
>>>> NAME 'regions'
>>>> EXPRESSION ('[NATURE]' eq 'Limite de région')
>>>> SIZE 3
>>>> COLOR 255 0 0
>>>> SYMBOL "circle"
>>>> LABEL
>>>> TYPE bitmap
>>>> FONT "verdana"
>>>> COLOR 0 0 0
>>>> SIZE 12
>>>> MAXSIZE 18
>>>> POSITION CC
>>>> ANGLE AUTO
>>>> BUFFER 2
>>>> END
>>>> END
>>>> PROJECTION
>>>> "init=epsg:2154"
>>>> END
>>>> TOLERANCE 5
>>>>END
>>>>Thanks
>>>>_______________________________________________
>>>>Mapserver-users mailing list
>>>>Mapserver-users at lists.gis.umn.edu
>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
