[Mapserver-users] qlayer : transparent.
Sebastien Vincent
svincent at idems.fr
Thu Apr 8 06:12:27 EDT 2004
Hello,
I work with query's, everything goes right :)
But I can get transparency on a layer used by qlayer.
This is the concerned section in my MapFile :
SYMBOL
NAME 'hachures'
TYPE vector
TRANSPARENT 50
POINTS
0 1
1 0
END
END
QUERYMAP
STATUS ON
STYLE SELECTED
COLOR 0 0 255
END
LAYER
NAME qcadastre
STATUS OFF
TYPE POLYGON
TRANSPARENCY 40
CONNECTIONTYPE OGR
CONNECTION "data/file.TAB"
DATA '0'
TEMPLATE "empty.htm"
HEADER "carte.htm"
FOOTER "empty.htm"
CLASS
COLOR 0 0 255
SYMBOL 'hachures'
SIZE 3
NAME "Resultat requete"
END
END
When I try to make qcadastre status to DEFAULT, it is transparent as
well. But when qlayer load it, it is not transparent.
I don't know what I'm doing wrong :/
If you saw this problem and solved it before, any help would be
appreciated :)
Thank a lot for previous questions :)
Best regards,
seb :)
