[Mapserver-users] querybyshape failing
Daniel Morissette
dmorissette at dmsolutions.ca
Tue Apr 13 21:59:21 EDT 2004
AARON KONING wrote:
> Yes, the queryByRect with the same coordinates returns the proper amount of records (all). Do you have any example code showing queryByShape used in this fashion?
If queryByRect() works then I can't see why queryByShape() wouldn't.
There may be a bug, or something missing in your script, but the problem
is not obvious. If you could file a script + mapfile + dataset to
reproduce this in bugzilla then we can try to see what's going on.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
