[Mapserver-users] installation in a shared hosting environment
Tyler Mitchell TMitchell at lignum.com
Mon Apr 19 12:22:43 EDT 2004
This is topic that I believe is worthy of a tutorial or more discussion. I
think many folks aim to get things running in this environment but get
stuck.  Anyone want to share more about the process and the limitations
(i.e. if you don't have shell access to compile)?
Tyler
mapserver-users-admin at lists.gis.umn.edu wrote on 04/13/2004 07:38:11 PM:
> That should work great, I have a similar setup on my system. I have
> virtual hosts where all of them use the standard php apache module and
> then in one virtual host I have installed php as cgi-bin with mapscript
> and all the php requests in that virtual host go to that php instead of
> the apache php module. You can do the same thing on a directory by
> directory basis if you want it not a big deal.
> Works great, haven't had a problem.
> -Steve
> Hal Mueller wrote:
> > I'm about to try again to install onto a shared hosting setup (the
Ensim
> > virtual server, running Linux, I think Redhat).
> > The shared hosting comes with Apache, PHP, and mySQL already
installed,
> > and maintained by the hosting company.  I don't want to break the
> > preinstalled Apache/PHP.  But I do specifically want PHPmapscript
> > available.
> > I'm about to install a second copy of PHP, in a separate clean
> > subdirectory, which will be used only to drive Mapserv/Mapscript.  Is
> > this a viable plan?  Anything to worry about?  Any suggestions on
config
> > options or other gotchas?
> > TIA,
> > Hal
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
