[Mapserver-users] installation in a shared hosting environment
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Apr 13 22:38:11 EDT 2004
That should work great, I have a similar setup on my system. I have
virtual hosts where all of them use the standard php apache module and
then in one virtual host I have installed php as cgi-bin with mapscript
and all the php requests in that virtual host go to that php instead of
the apache php module. You can do the same thing on a directory by
directory basis if you want it not a big deal.
Works great, haven't had a problem.
-Steve
Hal Mueller wrote:
> I'm about to try again to install onto a shared hosting setup (the Ensim
> virtual server, running Linux, I think Redhat).
> The shared hosting comes with Apache, PHP, and mySQL already installed,
> and maintained by the hosting company. I don't want to break the
> preinstalled Apache/PHP. But I do specifically want PHPmapscript
> available.
> I'm about to install a second copy of PHP, in a separate clean
> subdirectory, which will be used only to drive Mapserv/Mapscript. Is
> this a viable plan? Anything to worry about? Any suggestions on config
> options or other gotchas?
> TIA,
> Hal
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
