[Mapserver-users] request=GetMap& error in MapServer v4.1
Ed McNierney ed at topozone.com
Thu Apr 15 11:54:00 EDT 2004
Rene -
The WMS GetMap request specifies a particular map, while the map file
defines the set of map services available.  A given map file can provide
for multiple SRS, BBox, Width, Height, Layers, and Format options, so
the request needs to indicate what particular map is being requested
right now.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
Sent: Thursday, April 15, 2004 8:28 AM
To: dmorissette at dmsolutions.ca; RCorbet at gov.ns.ca
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] request=GetMap& error in MapServer v4.1
If we have to specify almost everything in the GetMap request, why do we
have to have it in the WMS server map file as well??
>>> "Daniel Morissette" <dmorissette at dmsolutions.ca> 2004-04-14 5:30:20
PM >>>
Ed McNierney wrote:
> I'm a little puzzled - your GetMap request is missing several
required
> parameters (SRS, BBox, Width, Height, Layers, etc.).  I'm surprised
it
> worked at all in 4.0.2.  The error message is (a little obscurely)
> complaining because you have no LAYERS at all.
Before V4.1, MapServer used to forgive all those missing parameters in
GetMap and use default values from the mapfile.
In 4.1 the checking has been made more strict on some parameters in
order to pass some of the tests in the OGC test suite, and the LAYERS
parameter is one of those parameters that we check for.  You probably
get the error on LAYERS because it's the first parameter that is checked
for, and once it finds one error it stops and doesn't report other
missing parameters.
Daniel
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
