[Mapserver-users] Itemquery - getting started, having problems
Richard Greenwood
rich at greenwoodmap.com
Sun Apr 18 18:53:43 EDT 2004
Mike Reilly wrote:
> Hi:
> I'm just starting to try to work with itemquery and itemnquery. I've
> read the cgi reference, the mapfile reference, trolled through the
> archives and spent a number of hours trying to get this started. I'm
> obvoiusly missing something significant, however. Here's what I'm
> working with:
> A number of shapefiles to create maps from - I have all other functions
> working on my application - can zoom, pan, query the map, etc. What I
> want to do now is be able to link to the map from other pages in order
> to display a single site - either point or polygon from one of two
> shapfiles - tuspoints and mergeplys. Both of these shapefiles have a
> field (attribute?) named SITEID. I want to be able to display these
> point or poly sites on my map based on whether they match a specific
> SITEID value. After looking through the docs and archives, I figured
> that forming a URL with mode=itemquery was what I wanted (am I going in
> the right direction here?). After looking at one of Richard Greenwood's
> sites, I figured this was probably teh correct way to go.
> I have not made any modifications to the shapefile I'm using in order to
> use mode=itemnquery (am I missing something here?). Here's an example
> of a URL I tried to create in order to get my map displayed correctly:
> http://192.168.0.3/cgi-bin/mapserv.exe?map=f:/program%20files/apache%20group/apache2/htdocs/Kitasoo/tus2-1.map&mode=itemquery&qitem=SITEID&qstring=1010&layer=landpl+streamln+lakespl+conmajl&qlayer=tuspoints
> This gives me the following output:
> msQueryByAttributes(): Search returned no results. No matching record(s)
> found.
> In the tuspoints layer, there is a site with a SITEID that has the value
> 1010. Not sure why I'm getting no matching records found. Can anyone
> point me in the right direction here?
Two things to try:
1. Be sure that the object having SITEID = 1010 is within the extents
that you have defined in your map file.
2. Add 'mapext=shapes' to your query string.
Richard Greenwood
www.greenwoodmap.com
