[Mapserver-users] Itemquery - getting started, having problems
Mike Reilly mikereilly_7 at hotmail.com
Sun Apr 18 20:55:18 EDT 2004
Bottom posting - see response at bottom.
>From: Richard Greenwood <rich at greenwoodmap.com>
>To: Mike Reilly <mikereilly_7 at hotmail.com>
>CC: mapserver-users at lists.gis.umn.edu
>Subject: Re: [Mapserver-users] Itemquery - getting started, having problems
>Date: Sun, 18 Apr 2004 16:53:43 -0600
>Mike Reilly wrote:
>>Hi:
>>I'm just starting to try to work with itemquery and itemnquery.  I've read
>>the cgi reference, the mapfile reference, trolled through the archives and
>>spent a number of hours trying to get this started.  I'm obvoiusly missing
>>something significant, however.  Here's what I'm working with:
>>A number of shapefiles to create maps from - I have all other functions
>>working on my application - can zoom, pan, query the map, etc.  What I
>>want to do now is be able to link to the map from other pages in order to
>>display a single site - either point or polygon from one of two shapfiles
>>- tuspoints and mergeplys.  Both of these shapefiles have a field
>>(attribute?) named SITEID.  I want to be able to display these point or
>>poly sites on my map based on whether they match a specific SITEID value.
>>After looking through the docs and archives, I figured that forming a URL
>>with mode=itemquery was what I wanted (am I going in the right direction
>>here?).  After looking at one of Richard Greenwood's sites, I figured this
>>was probably teh correct way to go.
>>I have not made any modifications to the shapefile I'm using in order to
>>use mode=itemnquery (am I missing something here?).  Here's an example of
>>a URL I tried to create in order to get my map displayed correctly:
>>http://192.168.0.3/cgi-bin/mapserv.exe?map=f:/program%20files/apache%20group/apache2/htdocs/Kitasoo/tus2-1.map&mode=itemquery&qitem=SITEID&qstring=1010&layer=landpl+streamln+lakespl+conmajl&qlayer=tuspoints
>>This gives me the following output:
>>msQueryByAttributes(): Search returned no results. No matching record(s)
>>found.
>>In the tuspoints layer, there is a site with a SITEID that has the value
>>1010.  Not sure why I'm getting no matching records found.  Can anyone
>>point me in the right direction here?
>Two things to try:
>1. Be sure that the object having SITEID = 1010 is within the extents that
>you have defined in your map file.
>2. Add 'mapext=shapes' to your query string.
>Richard Greenwood
>www.greenwoodmap.com
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
I have added mapext=shapes to the URL, and the extents as defined in my
mapfile include the entire data set in all shape files.  I've also tried
using other SITEID numbers.  Here is a snippet from my map file defining
some of the basics as well as including two shapefiles in the layer
(skipping inclusion of the other 20+ layers):
  NAME           EX2.1_
  IMAGETYPE      png
  EXTENT         768897.25886 810841.50306 876598.91242 913853.62854  # LAEA
  #EXTENT         -97.5 41.619778 -82.122902 49.38562 # Geographic
  SIZE          792 592
  SHAPEPATH      "f:/program files/apache group/apache2/htdocs/Kitasoo/tus"
  SYMBOLSET      "f:/program files/apache
group/apache2/htdocs/Kitasoo/symbols/symbols35.sym"
  FONTSET        "f:/fonts/fonts.list"
  IMAGECOLOR	207 245 255
  WEB
    TEMPLATE  'f:/program files/apache
group/apache2/htdocs/Kitasoo/tus2-1.html'
    IMAGEPATH 'f:/program files/apache group/apache2/htdocs/tmp/'
    IMAGEURL  'http://192.168.0.3/tmp/'
  END
LAYER # TUS polygon layer begins here
    NAME         tuspoints
    DATA         "mergeplys"
    STATUS       ON
    TYPE         POLYGON
    TOLERANCE 3
    PROJECTION
#      "init=epsg:4326"
    END
    CLASSITEM "LOCATION"
    CLASS
      EXPRESSION   "land"
      COLOR        160 160 255
      TEMPLATE     "templates/land_query.html"
      OUTLINECOLOR 0 200 0
    END
    CLASS
      EXPRESSION   "Ocean"
      COLOR        100 255 100
      OUTLINECOLOR 0 255 0
    END
  END
# ***** display all point layers begin here.
  LAYER
    NAME	"tuspoints"
    DATA        "tus points"
    STATUS      ON
    TYPE 	POINT
    MAXSCALE	5000000000
    TOLERANCE   3
    CLASS
      SYMBOL	7
      SIZE	6
      TEMPLATE  "templates/pointdata_query.html"
      COLOR	255 0 0
    END
  END
_________________________________________________________________
Tired of spam? Get advanced junk mail protection with MSN Premium
http://join.msn.com/?pgmarket=en-ca&page=byoa/prem&xAPID=1994&DI=1034&SU=http://hotmail.com/enca&HL=Market_MSNIS_Taglines
