RES: [Mapserver-users] mapserver demo cannot display png files
-- RESOLVED
Pericles S. Nacionales
nacional at cbs.umn.edu
Mon Apr 19 12:21:46 EDT 2004
The problem was incorrect path to the MAP_WEB_IMAGEPATH in index.html.
The DHTML example doesn't use this tmp directory and so doesn't have
encounter the problem.
-Perry
On Mon, 2004-04-19 at 10:28, Steve Lime wrote:
> Is it possible the browser being used can't display PNG files? MapServer
> itself would cough up an error if it couldn't deal with the format.
> Steve
> >>> "Gabriel Moricz" <gabriel at autofax.com.br> 04/19/04 7:24 AM >>>
> perhaps the name of the files inside the demo.map file....
> Or the png library is not installed...
> try to use mapserv -v, and see the imputs and outputs...
> See my mapserv -v example...
> MapServer version 4.0.2 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
> OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
> INPUT=GDAL INPUT=SHAPEFILE
> as u see...OUTPUT=PNG
> I hope that it could help u..
> Gabriel Moricz
> -----Mensagem original-----
> De: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]Em nome de ESSC Admin
> Enviada em: domingo, 18 de abril de 2004 06:00
> Para: mapserver-users at lists.gis.umn.edu
> Assunto: [Mapserver-users] mapserver demo cannot display png files
> Hello. The mapserver demo works but cannot display png files. What
> could
> be wrong?
> Thanks.
> Regards
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
"He's no geek.His tan's too good." -Benjamin Choate
