[Mapserver-users] junk pointer revisited
Robert A Carr
racarr at fs.fed.us
Fri Apr 23 14:59:38 EDT 2004
Toomas,
Did you compile PHP 4.3.6 from source? If so, did the configure string
specify '--without-tiff'? A few months ago I performed a similar upgrade
on FreeBSD 4.9, and until I recompiled PHP without tiff support, I received
the junk pointer error.
Bob Carr
USDA Forest Service - Eastern Region
racarr at fs.fed.us
| | "Toomas Aas" |
| | <toomas.aas at raad.tartu.ee> |
| | Sent by: |
| | mapserver-users-admin at lists.|
| | gis.umn.edu |
| | 04/22/2004 12:43 PM |
| To: mapserver-users at lists.gis.umn.edu |
| cc: |
| Subject: [Mapserver-users] junk pointer revisited |
Hello!
I'm running Mapserver and PHP/Mapscript on FreeBSD 4.9. A couple of
days ago I upgraded PHP from 4.3.4 to 4.3.6 and then I also re-compiled
Mapserver using the newer PHP source tree. After that I'm seeing again
mapserv dying with Signal 10 in /var/log/messages:
Apr 22 15:21:45 mail /kernel: pid 52647 (mapserv), uid 80: exited on signal
10
and this message in Apache's error_log:
mapserv in realloc(): warning: junk pointer, too high to make sense
[Thu Apr 22 15:21:45 2004] [error] [client 213.35.245.74] Premature end of
script headers
I had exactly the same problem when I first installed Mapserver 4.0.1
and back then I posted this message:
http://mapserver.gis.umn.edu/cgi-bin/wilma_hiliter/mapserver-users/0312/msg00100.html?line=3#hilite
Someone recommended me off-list that I shouldn't use both --with-tiff and
--with-gdal, so I recompiled without --with-tiff and the errors went away.
Now when compiling Mapserver again I made sure to not use --with-tiff but
still the error messages returned. Otherwise the ./configure line is
exactly
the same (except that newer PHP source tree is used).
I also noticed that immediately *before* the "junk pointer" message in
Apache's error_log is this message:
wmftogif: not found
Error: Can't open file (/home/mapserver/www/tmp/1082636396526241.jpg)
Might this indicate that this is all simply an error in our PHP/Mapscript
application? Can a "junk pointer" message be caused by wmftogif (whatever
that is) not finding a file it wants? Unfortunately I am not the one who
develops applications on this server, I just install the necessary base
software. So I don't know whether the error is caused by me or by
application
developers.
Toomas Aas | toomas.aas at raad.tartu.ee | http://www.raad.tartu.ee/~toomas/
* My wife ran off with my best friend, and i sure do miss him.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
