[Mapserver-users] EXTENT and PROJECTION
Tyler Mitchell
TMitchell at lignum.com
Mon Apr 26 16:18:01 EDT 2004
I very real possibility could be that your projection in the geotiff is
just plain wrong. You may want to hunt that down from the source.
mapserver-users-admin at lists.gis.umn.edu wrote on 04/26/2004 12:32:57 PM:
> Thanks all!
> I just worked through some of the suggestions.
> I do have mapserver running and I'm able to display the file
> mod09a12003161_ugl_ll_idxa.tif with no problems. I would assume had I
> screwed up something in the installation that affected image display
> capabilities that I would not be able to display this file.
> I did have both tiff and gdal compiled and I followed Pericles
> suggestion and recompiled. This had no affect. I did change the
> IMAGECOLOR and I do get a big colored square now.
> I have also ruled out any permisions/path problems.
> I will now try messing with the extents and the units of the extents but
> nothing I've tried so far has given me anything different.
> -ethan
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
