[Mapserver-users] EXTENT and PROJECTION
Pericles S. Nacionales
nacional at cbs.umn.edu
Mon Apr 26 17:23:01 EDT 2004
Ethan,
I just checked your original post and discovered that you didn't have
UNITS specified on your mapfile. Add "UNITS METERS" on the main map
block and see if that fixes it. Ex:
MAP
<snip>
EXTENT ...
UNITS METERS # Add this
PROJECTION
END
<snip>
END
-Perry
On Mon, 2004-04-26 at 14:32, Ethan Alpert wrote:
> Thanks all!
> I just worked through some of the suggestions.
> I do have mapserver running and I'm able to display the file
> mod09a12003161_ugl_ll_idxa.tif with no problems. I would assume had I
> screwed up something in the installation that affected image display
> capabilities that I would not be able to display this file.
> I did have both tiff and gdal compiled and I followed Pericles
> suggestion and recompiled. This had no affect. I did change the
> IMAGECOLOR and I do get a big colored square now.
> I have also ruled out any permisions/path problems.
> I will now try messing with the extents and the units of the extents but
> nothing I've tried so far has given me anything different.
> -ethan
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
