[Mapserver-users] POSTGIS - subselect problem
Ethan Alpert
ealpert at digitalglobe.com
Tue Apr 27 10:26:45 EDT 2004
I believe you have an SQL syntax error.
SQL requires the a table to be referenced after from.
-e
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Alexandros
Chimarios
Sent: Tuesday, April 27, 2004 7:55 AM
To: Mapserver Users List
Subject: [Mapserver-users] POSTGIS - subselect problem
Hello,
I have a problem with POSTGIS and in particular with subselects. I have
a
POSTGIS layer and everything go well when i put :
DATA " geolocation from unit_tracks USING UNIQUE unit_id USING SRID =
-1 "
... but when i put the following data(which theoritically is the same
data
with the previous one) I get a segmentation fault :
DATA " geolocation from (SELECT geolocation from unit_tracks) as foo
using
unique oid using srid=-1 "
Could anyone explain me what's happening here since subselecting is very
important thing.
Thanx
Alexandros.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
