[Mapserver-users] WFS-Client
Yewondwossen Assefa assefa at dmsolutions.ca
Tue Apr 27 12:25:32 EDT 2004
Daniel Morissette wrote:
> Silke Reimer wrote:
>> The problem is, that deegree only excepts HTTP-Post-Request for the
>> WFS-Server while UMN MapServer as WFS-clients only creates
>> HTTP-Get-Requests.
> I believe MapServer v4.2 now uses the POST method by default for WFS
> layers, so one solution may be to upgrade to MapServer 4.2. Can you
> please confirm that Assefa?
Yes. By default the request is sent using the Post Method.  There is a
layer level metadata called wfs_request_method that can be set to GET if
you want to use the Get method ("wfs_request_method" "GET").  Note that
there was an error on the metadata name in the release of 4.2b1 (the
names used was wms_request_method instead of wfs_request_method). This
has been fixed in mapserver cvs.
Later,
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
