teacher points on California zips revisited
Joseph Norris sirronj at PACBELL.NET
Thu Dec 2 13:13:07 EST 2004
Ok - here is my map file.  I have set the min/max of the layers so that when
I zoom in I should be able to see the teacher points and loose the "Teachers
in Zip" coloring - this happens - sort of.  When I zoom in I loose the color
and get the teacher circle in the legend but I do not get any polygon
outline and no circles for the teachers.
MAP
  EXTENT 5706290.827754 -192053.2 9127890.404246 3226086.749
  TEMPLATEPATTERN "map"
  IMAGECOLOR 255 255 255
  IMAGETYPE gif
  SHAPEPATH
"/usr/local/apache/htdocs/mco.communityservers.com/htdocs/maps/teacher/tdata
  SIZE 700 700
  STATUS ON
  UNITS FEET
  PROJECTION
    "init=epsg:26942"
  END
  NAME "calmap"
  OUTPUTFORMAT
    NAME gif
    MIMETYPE image/gif
    DRIVER GD/GIF
    EXTENSION gif
    IMAGEMODE PC256
    TRANSPARENT FALSE
  END
  SYMBOL
    NAME "circle"
    TYPE ELLIPSE
    FILLED TRUE
    POINTS
      1 1
    END
  END
  LEGEND
    KEYSIZE 20 10
    KEYSPACING 5 5
    LABEL
      SIZE MEDIUM
      TYPE BITMAP
      BUFFER 0
      COLOR 0 0 0
      FORCE FALSE
      MINDISTANCE -1
      MINFEATURESIZE -1
      OFFSET 0 0
      PARTIALS TRUE
      POSITION CC
    END
    POSITION LL
    STATUS EMBED
  END
  QUERYMAP
      COLOR 255 255 0
    SIZE -1 -1
    STATUS OFF
    STYLE HILITE
  END
  SCALEBAR
      COLOR 0 0 0
    INTERVALS 4
    LABEL
      SIZE MEDIUM
      TYPE BITMAP
      BUFFER 0
      COLOR 0 0 0
      FORCE FALSE
      MINDISTANCE -1
      MINFEATURESIZE -1
      OFFSET 0 0
      PARTIALS TRUE
    END
    POSITION LL
    SIZE 200 3
    STATUS OFF
    STYLE 0
    UNITS MILES
  END
  WEB
    IMAGEPATH ""
    IMAGEURL ""
    QUERYFORMAT text/html
  END
  LAYER
    CLASSITEM "zcta"
    DATA "cal_zp_st"
    NAME "calzip"
    SIZEUNITS PIXELS
    STATUS DEFAULT
    TOLERANCE 0
    TOLERANCEUNITS PIXELS
    MINSCALE 1478131.017053
    TYPE POLYGON
    PROJECTION
     "init=epsg:26942"
    END
    UNITS FEET
    CLASS
      NAME "Teachers in Zips"
      EXPRESSION
/95822|94117|93230|94903|91941|94110|95818|95815|91006|92503|90305|90042|953
37|95020|90242|94123|92084|94949
|93702|92802|95648|94103|95135|91103|95687|95632|95329|92024|91326|92054|935
60|93010|90043|90805|93023|90012|94606|91405|9195
0|90720|93405|94124|91935|95128|95124|94112|92663|92308|94087|92630|92105|94
115|94520|90033|94040|94621|92804|95501|91764|939
07|92186|94901|95210|94509|95076|94513|91910|95825|90032|93274|94612|91601|9
5351|93960|90025|95608|94952|90405|94105|90241|95
665|94404|92028|92115|92629|92083|92107|92117|92675|93711|38125|92570|94558|
93291|93720|95816|92320|95864|94107|94607|94131|9
0018|95125|91789|91101|95118|96001|94710|95032|95570|94121|92507|90262|95139
|95692|94704|94611|92585|94402|92705|90063|94560|
93727|94549|90015|95993|90274|93901|90065|90232|91977|93212|91730|92127|9239
2|92111|93706|95452|94804|91107|91945|92612|94539
|93924|92505|93710|92019|92801|91962|95834|90270|90802|95126|94555|95823|943
03|92108|92128|95690|92064|92071|92120|92025|9310
9|94580|94904|91406|94108|94070|74580|93034|90066|92509|94401|90059|95562|94
947|95242|91911|95521|93111|95658|94122|94102|907
45|95050|93449|95060|93446|93726|95969|95110|91104|91001|90049|95838|94577|9
2131|92040|95204|94545|91932|95018|91411|92106|94
568|95304|95407|94531|95678|90292|92243|91711|92410|95070|93004|92008|95829|
93908|93721|94703|94954|95959|94134|95428|90003|9
1384|93591|94304|94501|94133|95670|95814|95127|93012|94591|92121|90220|94806
|92591|95531|90504|94705|94530|95376|93003|94707|
95841|95667/
      STYLE
          COLOR 255 102 102
        MAXSIZE 100
        MINSIZE 1
        SIZE 1
        SYMBOL 0
      END
    END
    CLASS
      NAME "Zip Boundries"
      EXPRESSION /./
      STYLE
        MAXSIZE 100
        MINSIZE 1
          OUTLINECOLOR 204 204 204
        SIZE 1
        SYMBOL 0
      END
    END
  END
  LAYER
    NAME "points"
    SIZEUNITS PIXELS
    STATUS DEFAULT
    TEMPLATE "bogus.html"
    TOLERANCE 10
    TYPE POINT
    UNITS FEET
    MAXSCALE 1478131.017053
    PROJECTION
        "proj=latlong"
    END
    CLASS
      NAME "Teachers"
      LABEL
        SIZE MEDIUM
        TYPE BITMAP
        BUFFER 2
        COLOR 255 0 0
        FORCE FALSE
        MINDISTANCE -1
        MINFEATURESIZE -1
        OFFSET 0 0
        PARTIALS FALSE
        POSITION AUTO
      END
      STYLE
        COLOR 255 255 0
        OUTLINECOLOR 0 0 0
        SIZE 8
        SYMBOL "circle"
      END
    END
    FEATURE
      POINTS
        38.5263 -121.507
      END
List of points for lat/long with text of teacher's names
#Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print @c=map chr
$_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,14,-
68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu]On
Behalf Of David Fawcett
Sent: Thursday, December 02, 2004 9:20 AM
To: MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] teacher points on California zips
revisited
In addition to what Ethan says,
For your teachers layer, you could use the below projection block in
place of projection=latlong (this is just the EPSG code for latlong):
 PROJECTION
     "init=epsg:4267"
 END
David J. Fawcett
MN Office of Environmental Assistance
>>> Ethan Alpert <ealpert at DIGITALGLOBE.COM> 12/2/2004 11:10:22 AM >>>
Go back and read the answers to your previous posts. What your
PROJECTION blocks should be was already discussed.
-e
On
Behalf Of Joseph Norris
Sent: Thursday, December 02, 2004 10:08 AM
revisited
Thanks for this information - so do I have to take my point file and
create it within the state plane also?  I so how will I do that build?
@c=map
chr
14,-
Behalf Of Ethan Alpert
Sent: Thursday, December 02, 2004 9:01 AM
revisited
Those are meters not lat/lon and are probably in the California state
plane projection. You posted the .prj previously which clearly showed
that you data was in the state plane projection.
-e
On
Sent: Thursday, December 02, 2004 9:55 AM
Subject: [UMN_MAPSERVER-USERS] teacher points on California zips
revisited
Hello,
Here we go again.  I finally did the following:
Created a shape file of all of my teacher points by their lat/long.
Dropped the California zip code map on to my laptop and then the new
teacher points file. I then used fGIS
(http://www.digitalgrove.net/fgis.htm)  and loaded the California zip
layer and then my new teacher point layer. I can zoom to the zip layer
but when I zoom to the point layer it is way far away from the zip
layer.  I did this as a sanity check because I did not think that I
was
even producing the teacher point layer.  The questions are:
If I create a point shape file based upon lat/lon and I have the
California zip file - why will one not lie over the other - are they
not
both based upon lat/long?
Can I open my teacher dbf file, and go search for the zip in the
California zip file and then rebuild the teacher point file with
coordinates from the California zip file thus allowing me to place my
points in the zip polygon that they belong to?
In my California shape file on a dump I get:
     ( 5983045.379, 3224996.563, 0, 0)
     ( 5989542.292, 3224832.974, 0, 0)
     ( 5989921.623, 3224823.475, 0, 0)
     ( 5989953.049, 3224815.898, 0, 0)
     ( 5990112.487, 3224777.458, 0, 0)
     ( 5991452.255, 3224753.633, 0, 0)
     ( 5993483.853, 3224717.643, 0, 0)
     ( 5993800.929, 3224702.331, 0, 0)
     ( 6011910.153, 3224087.577, 0, 0)
     ( 6017051.977, 3223915.448, 0, 0)
     ( 6026300.989, 3223711.249, 0, 0)
     ( 6026888.615, 3222812.493, 0, 0)
What do these values mean - are they lat/long values?
Thanks for all of the help that you have given me so far.
@c=map
chr
14,-
