Shapefile field problem
Abe Gillespie agillesp at VT.EDU
Tue Dec 7 16:17:10 EST 2004
The problem with adding a value for that attribute corrupts the test
case.  Can you try the following PHP code and compare your results with
mine?
[php]
<html>
<body>
                dl("php_mapscript.so");
                $map = ms_newMapObj("/Users/abe/Sites/ms_test/test.map");
                for ($i = 0; $i < $map->numlayers; $i++)
                        $l = $map->getLayer($i);
                        putBrLine($l->name.", type: ".$l->type);
                        if ($l->data != null)  // Shape files with data.
                                $l->open();
                                $s = $l->getShape(-1, 0);
                                $vals = $s->values;
                                putBrLine("field count: ".count($vals));
                                while ($fld = current($vals))
                                        putBrLine("&nbsp;&nbsp;".key($vals));
                                        next($vals);
                                $s->free();
                                $l->close();
                function putBrLine($line)
                        echo "$line<br>¥n";
</body>
</html>
[output]
test, type: 2
field count: 54
   ACAD_TEXT
   COUNT
   ACCOUNT_NU
See how there's a discrepancy between the field count and the number of
field names that get dumped?  From my experience, the field just after
ACCOUNT_NU has a NULL value.  I see the same behavior on my Mac OS X
and Debian Linux installs.
-Abe
On Dec 7, 2004, at 2:15 PM, Jeff McKenna wrote:
> Abe,
> I made a tiny mapfile with your test shp, and i see labels properly in
> MapServer with it.  I added an attribute in the "OWNERS_NAM" field and
> I successfully displayed it in mapserver.  Am i misunderstanding your
> problem somehow?  (mapfile below)
> jeff
> MAP
>   NAME "field-test"
>   STATUS ON
>   EXTENT 1260565.500000 941362.000000 1261605.125000 942198.625000
>   SIZE 400 300
>   SHAPEPATH "D:/DMSG/projects/mapserver-bugs/"
>   SYMBOLSET "../etc/symbols.sym"
>   FONTSET "../etc/fonts.txt"
>   IMAGETYPE gif
>   IMAGECOLOR 255 255 255
>   UNITS METERS
>   WEB
>     IMAGEPATH "/ms4w/tmp/ms_tmp/"
>     IMAGEURL "/ms_tmp/"
>     METADATA
>     END
>   END
>   OUTPUTFORMAT
>     NAME "gif"
>     MIMETYPE "image/gif"
>     DRIVER "GD/GIF"
>     EXTENSION "gif"
>     IMAGEMODE PC256
>     TRANSPARENT FALSE
>   END
> LAYER
>   NAME test
>   TYPE POLYGON
>   STATUS ON
>   DATA test
>   LabelItem "OWNERS_NAM"
>   CLASS
>     NAME "ttt"
>     COLOR 0 255 0
>     LABEL
>       COLOR  255 0 0
>       FONT fritqat-italic
>       TYPE truetype
>       SIZE 8
>       POSITION AUTO
>       PARTIALS FALSE
>       OUTLINECOLOR 255 255 255
>     END
>   END
> END # Layer
> END
> Abe Gillespie wrote:
>> I do appreciate the help, but I'm not looking for an "external to
>> MapServer" way of getting access to my DBF field values.  I just use
>> my
>> PHP script to *reveal* problematic shapefile fields.  When there is a
>> problem it's unusable to MapServer!  I.e.: I can't use the field for
>> labelling.
>> -Abe
>> On Dec 7, 2004, at 11:27 AM, Ryan, Adam wrote:
>>> Abe,
>>> Here's a routine I use to get the header information (field info)
>>> from
>>> a dbf
>>> file.
>>> //      ==========      iDbf_fields     ==============
>>> //      $f is a dbf file path, returns an array of field arrays
>>> function iDbf_fields($f){
>>>         $h = fopen($f,"rb");
>>>         $a =
>>> unpack("cversion/cyy/cmm/cdd/inumrecs/sheadsize/
>>> srecsize",fread($h,12));
>>>         fread($h,20);   //skip some reserved space
>>>         for($i=0;$i<($a["headsize"]-33)/32;$i++){
>>>                 $fa = array();
>>>                 $fname = trim(fread($h,11));
>>>                 $fa["type"] = fread($h,1);
>>>                 fread($h,4);
>>>                 $fa =
>>> array_merge($fa,unpack("Clen/Cpre",fread($h,2)));
>>>                 fread($h,14);
>>>                 $flds[$fname] = $fa;
>>>         fclose($h);
>>>         return $flds;
>>> When I generate a result table I'll go through the array like this:
>>> ($so is
>>> the shape Object)
>>>                         foreach($flds as $fname => $fA){
>>>                                 $val = $so->values[$fname];
>>>                                 if ($val==null)$val="&nbsp";
>>>                                 $val = str_replace("  ","
>>> &nbsp;",$val);
>>>                                 if ($fA["type"]=="D"){$val =
>>> substr($val,4,2)."-".substr($val,6,2)."-".substr($val,0,4);}
>>>                                 echo "<td>$val</td>";}
>>> Cheers to all,
>>> Adam
>>>> -----Original Message-----
>>>> From: Abe Gillespie [mailto:agillesp at VT.EDU]
>>>> Sent: Monday, December 06, 2004 5:14 PM
>>>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>>>> Subject: Re: [UMN_MAPSERVER-USERS] Shapefile field problem
>>>> It's a regular shapefile.  I think I've mostly narrowed it
>>>> down.  It seems to me (though I may be completely off) that
>>>> MapServer loads the first record of the DBF in order to get
>>>> the field definitions.  If the first record has a string
>>>> field and the value is zero length it won't give me the field
>>>> (though the field count is always correct).  In addition, it
>>>> won't give me any fields after that either.  If, however, I
>>>> make sure that field has some value (a dash, an "x",
>>>> whatever) then the field definition will come in correctly.
>>>> I still haven't narrowed down a problematic number field
>>>> though.  Mind you, this is all done in MapServer PHP v. 4.2.0.
>>>> -Abe
>>>>>> A good amount of fields aren't showing up in MapServer for
>>>> me.  I use
>>>>>> the following PHP script to dump out all layers and their
>>>> fields for
>>>>>> debugging.  Does MapServer have problems with certain data
>>>> types or
>>>>>> certain values in a row?
>>>>> Are you using a tiled shapefile layer or is this a regular
>>>> shapefile
>>>>> layer?
>>>>>  Daniel Morissette               dmorissette at dmsolutions.ca
>>>>>  DM Solutions Group              http://www.dmsolutions.ca/
> Jeff McKenna
> GIS Specialist
> DM Solutions Group Inc.
